주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Connect Four Electronic Handheld Screen Replacement
필요한 것
    1. Connect Four Electronic Handheld Screen Replacement, Ensure the device is off.: 1 단계, 이미지 1개 중 1개
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      댓글 쓰기
    2. Connect Four Electronic Handheld Screen Replacement, Removing the battery casing.: 2 단계, 이미지 2개 중 1개 Connect Four Electronic Handheld Screen Replacement, Removing the battery casing.: 2 단계, 이미지 2개 중 2개
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      댓글 쓰기
    1. Connect Four Electronic Handheld Screen Replacement, Removing/Replacing the Back Casing: 3 단계, 이미지 2개 중 1개 Connect Four Electronic Handheld Screen Replacement, Removing/Replacing the Back Casing: 3 단계, 이미지 2개 중 2개
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      댓글 쓰기
    1. Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 4 단계, 이미지 3개 중 1개 Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 4 단계, 이미지 3개 중 2개 Connect Four Electronic Handheld Screen Replacement, Detaching the circuit board.: 4 단계, 이미지 3개 중 3개
      • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
      • Using a plastic opening tool, lever the circuit board just enough to where you can easily access the button sheet.
      댓글 쓰기
    2. Connect Four Electronic Handheld Screen Replacement, Removing the Circuit Board: 5 단계, 이미지 2개 중 1개 Connect Four Electronic Handheld Screen Replacement, Removing the Circuit Board: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Pop out the wires, connected to the battery terminals, out of their place. You can use a plastic opening tool or fine tweezers for this step.
      • The wires in this image have already been detached.
      • Check that there is no power going into the device that could pose any shock hazard.
      • Once the terminals are out of place, remove the circuit board.
      댓글 쓰기
    3. Connect Four Electronic Handheld Screen Replacement, Replacing the Screen: 6 단계, 이미지 1개 중 1개
      • Take the old screen out.
      • Replace the old screen with the new screen.
      • Ensure that the screen is facing right side up, where there is more yellow space under the checkered board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Wil
회원 가입일: 10/22/14
313 평판
안내서 3개를 작성함
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G11
3 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 27
전체 시간: 815
