주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Connect Four Electronic Handheld Speaker Replacement
필요한 것
    1. Connect Four Electronic Handheld Speaker Replacement, Ensure the device is off.: 1 단계, 이미지 1개 중 1개
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
      댓글 쓰기
    2. Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: 2 단계, 이미지 2개 중 1개 Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: 2 단계, 이미지 2개 중 2개
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
      댓글 쓰기
    1. Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: 3 단계, 이미지 2개 중 1개 Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: 3 단계, 이미지 2개 중 2개
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
      댓글 쓰기
    1. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 4 단계, 이미지 3개 중 1개 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 4 단계, 이미지 3개 중 2개 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 4 단계, 이미지 3개 중 3개
      • If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5.
      • Locate the speaker on the back casing.
      • Using a spudger, wedge the speaker out of its place until it slides out.
      • Take the replacement speaker and wedge it back into its space.
      댓글 쓰기
    2. Connect Four Electronic Handheld Speaker Replacement, Re-Soldering the Speaker Wire: 5 단계, 이미지 1개 중 1개
      • Using a soldering iron, solder both red wires to their appropriate connections.
      • Be extremely careful when using a soldering iron! Contact with the tip could cause severe burns.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Wil
회원 가입일: 10/22/14
313 평판
안내서 3개를 작성함
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G11
3 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 25
전체 시간: 617
