주요 콘텐츠로 건너뛰기
Contixo V9 Motherboard Replacement
필요한 것
  1. Contixo V9 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Contixo V9 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Find the separation line between the front and back side of the device on the outer edge of the tablet.
    • Use the plastic opening tool to pry apart the tablet, lifting the face off.
  2. Contixo V9 Motherboard Replacement: 2 단계, 이미지 1/3 Contixo V9 Motherboard Replacement: 2 단계, 이미지 2/3 Contixo V9 Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the three screws along the perimeter of the motherboard using the Phillips #000 screwdriver to unscrew.
  3. Contixo V9 Motherboard Replacement: 3 단계, 이미지 1/3 Contixo V9 Motherboard Replacement: 3 단계, 이미지 2/3 Contixo V9 Motherboard Replacement: 3 단계, 이미지 3/3
    • Locate the three golden ribbons along the perimeter of the motherboard.
    • There are two dark tabs; pull each away from the cream connection port. Once tabs are in open position remove the gold ribbon.
    • Flip up the dark tab and pull the gold ribbon away.
    • Do not pull the the cables harshly as it could rip the ribbon.
    • Reference this guide for more help with attaching or detaching cables.
  4. Contixo V9 Motherboard Replacement: 4 단계, 이미지 1/3 Contixo V9 Motherboard Replacement: 4 단계, 이미지 2/3 Contixo V9 Motherboard Replacement: 4 단계, 이미지 3/3
    • Locate the battery on the opened tablet.
    • Use the spudger or one of the blue iFixit tools to lift the battery from the base of the tablet.
    • It is possible to use your hand to pry the battery away from the base of the tablet but not recommended.
  5. Contixo V9 Motherboard Replacement: 5 단계, 이미지 1/3 Contixo V9 Motherboard Replacement: 5 단계, 이미지 2/3 Contixo V9 Motherboard Replacement: 5 단계, 이미지 3/3
    • Detach the motherboard from the battery by pressing the soldering tip tool to each of the three connection points.
    • Exercise caution when desoldering the battery.
    • The tool located in the pictures is not the soldering tip tool but rather used for reference of where to detach.
    • Reference this guide for more help with soldering and desoldering the connections.
  6. Contixo V9 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard from the base of the device. Switch with replacement.
결론
Janiya M.
회원 가입일: 09/12/23
133 평판
안내서 1개 작성함
University of North Texas, Team 3-4, Coppersmith Fall 2023 University of North Texas, Team 3-4, Coppersmith Fall 2023 회원
UNT-COPPERSMITH-F23S3G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 109
