주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Contour Roam2 Back Door Replacement
필요한 것
    1. Contour Roam2 Back Door Replacement, Record Slider: 1 단계, 이미지 1개 중 1개
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      댓글 쓰기
    2. Contour Roam2 Back Door Replacement: 2 단계, 이미지 2개 중 1개 Contour Roam2 Back Door Replacement: 2 단계, 이미지 2개 중 2개
      • Rotate the metal ring counterclockwise until completely removed.
      댓글 쓰기
    3. Contour Roam2 Back Door Replacement: 3 단계, 이미지 2개 중 1개 Contour Roam2 Back Door Replacement: 3 단계, 이미지 2개 중 2개
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      댓글 쓰기
    4. Contour Roam2 Back Door Replacement: 4 단계, 이미지 3개 중 1개 Contour Roam2 Back Door Replacement: 4 단계, 이미지 3개 중 2개 Contour Roam2 Back Door Replacement: 4 단계, 이미지 3개 중 3개
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      댓글 쓰기
    5. Contour Roam2 Back Door Replacement: 5 단계, 이미지 1개 중 1개
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      댓글 쓰기
    1. Contour Roam2 Back Door Replacement, Mounting Piece: 6 단계, 이미지 2개 중 1개 Contour Roam2 Back Door Replacement, Mounting Piece: 6 단계, 이미지 2개 중 2개
      • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
      댓글 쓰기
    2. Contour Roam2 Back Door Replacement: 7 단계, 이미지 2개 중 1개 Contour Roam2 Back Door Replacement: 7 단계, 이미지 2개 중 2개
      • Open the back door by your thumb and index finger on sides of back door and pull upward.
      댓글 쓰기
    3. Contour Roam2 Back Door Replacement: 8 단계, 이미지 1개 중 1개
      • Using your thumb, pry sides outward on back of mount piece.
      • This will loosen mount piece for removal in proceeding step.
      • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
      댓글 쓰기
    4. Contour Roam2 Back Door Replacement: 9 단계, 이미지 2개 중 1개 Contour Roam2 Back Door Replacement: 9 단계, 이미지 2개 중 2개
      • Remove and replace mount piece.
      댓글 쓰기
    1. Contour Roam2 Back Door Replacement, Back Door: 10 단계, 이미지 1개 중 1개
      • Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
      • After removing the metal bar, the spring will become loose and may fall out on its own.
      댓글 쓰기
    2. Contour Roam2 Back Door Replacement: 11 단계, 이미지 1개 중 1개
      • Remove and replace back door.
      • Door should easily be removed by pulling away from main body of camera.
      • As door is being pulled away, the spring may fall out own its own.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jamie Maple
회원 가입일: 03/11/15
310 평판
안내서 2개를 작성함
Colorado Springs, Team 4-5, Panko Spring 2015 Colorado Springs, Team 4-5, Panko Spring 2015 회원
UCCS-PANKO-S15S4G5
3 회원들
안내서 10개를 작성함
1가이드 댓글
Where can I get a replacement back door for an original contour roam shipped international? Contour will not reapond to my requests.
The Dude - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 34
전체 시간: 2,211
