주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Contour Roam2 Mounting Piece Replacement
필요한 것
    1. Contour Roam2 Mounting Piece Replacement, Record Slider: 1 단계, 이미지 1개 중 1개
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      댓글 쓰기
    2. Contour Roam2 Mounting Piece Replacement: 2 단계, 이미지 2개 중 1개 Contour Roam2 Mounting Piece Replacement: 2 단계, 이미지 2개 중 2개
      • Rotate the metal ring counterclockwise until completely removed.
      댓글 쓰기
    3. Contour Roam2 Mounting Piece Replacement: 3 단계, 이미지 2개 중 1개 Contour Roam2 Mounting Piece Replacement: 3 단계, 이미지 2개 중 2개
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      댓글 쓰기
    4. Contour Roam2 Mounting Piece Replacement: 4 단계, 이미지 3개 중 1개 Contour Roam2 Mounting Piece Replacement: 4 단계, 이미지 3개 중 2개 Contour Roam2 Mounting Piece Replacement: 4 단계, 이미지 3개 중 3개
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      댓글 쓰기
    5. Contour Roam2 Mounting Piece Replacement: 5 단계, 이미지 1개 중 1개
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      댓글 쓰기
    1. Contour Roam2 Mounting Piece Replacement, Mounting Piece: 6 단계, 이미지 2개 중 1개 Contour Roam2 Mounting Piece Replacement, Mounting Piece: 6 단계, 이미지 2개 중 2개
      • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
      댓글 쓰기
    2. Contour Roam2 Mounting Piece Replacement: 7 단계, 이미지 2개 중 1개 Contour Roam2 Mounting Piece Replacement: 7 단계, 이미지 2개 중 2개
      • Open the back door by your thumb and index finger on sides of back door and pull upward.
      댓글 쓰기
    3. Contour Roam2 Mounting Piece Replacement: 8 단계, 이미지 1개 중 1개
      • Using your thumb, pry sides outward on back of mount piece.
      • This will loosen mount piece for removal in proceeding step.
      • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
      댓글 쓰기
    4. Contour Roam2 Mounting Piece Replacement: 9 단계, 이미지 2개 중 1개 Contour Roam2 Mounting Piece Replacement: 9 단계, 이미지 2개 중 2개
      • Remove and replace mount piece.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matthew Kofsky
회원 가입일: 03/11/15
548 평판
안내서 3개를 작성함
Colorado Springs, Team 4-5, Panko Spring 2015 Colorado Springs, Team 4-5, Panko Spring 2015 회원
UCCS-PANKO-S15S4G5
3 회원들
안내서 10개를 작성함
2가이드 댓글
Hi i need this part...
julmarte - 답글 공유
I Need a battery, and check up.
Too many small screws for me, I am using it on a home defense air powered 50 cal with orange top. need to have a mount for that Ball Shooter. where can I get that project I live in the 831 AC
Or is their something used already working I got this needing a battery.
Help from a Person I can mail it
Thanks Dudley
Dudley Walsh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 32
전체 시간: 1,927
