주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Contour Roam2 Waterproof Action Camera Record Slider Replacement
필요한 것
  1. Contour Roam2 Waterproof Action Camera Record Slider Replacement, Record Slider: 1 단계, 이미지 1개 중 1개
    • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
    • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
    댓글 쓰기
  2. Contour Roam2 Waterproof Action Camera Record Slider Replacement: 2 단계, 이미지 2개 중 1개 Contour Roam2 Waterproof Action Camera Record Slider Replacement: 2 단계, 이미지 2개 중 2개
    • Rotate the metal ring counterclockwise until completely removed.
    댓글 쓰기
  3. Contour Roam2 Waterproof Action Camera Record Slider Replacement: 3 단계, 이미지 2개 중 1개 Contour Roam2 Waterproof Action Camera Record Slider Replacement: 3 단계, 이미지 2개 중 2개
    • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
    댓글 쓰기
  4. Contour Roam2 Waterproof Action Camera Record Slider Replacement: 4 단계, 이미지 3개 중 1개 Contour Roam2 Waterproof Action Camera Record Slider Replacement: 4 단계, 이미지 3개 중 2개 Contour Roam2 Waterproof Action Camera Record Slider Replacement: 4 단계, 이미지 3개 중 3개
    • Grab the camera on both sides and slide the outer shell forward until completely removed.
    댓글 쓰기
  5. Contour Roam2 Waterproof Action Camera Record Slider Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the record slider out.
    • The record slider should come out easily no matter the position (forward or backward).
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matthew Kofsky
회원 가입일: 03/11/15
548 평판
안내서 3개를 작성함
Colorado Springs, Team 4-5, Panko Spring 2015 Colorado Springs, Team 4-5, Panko Spring 2015 회원
UCCS-PANKO-S15S4G5
3 회원들
안내서 10개를 작성함
2가이드 댓글
I have had this camera since I was 16 I am 21 now and there was something wrong with the slider I am glad I didn't get rid of it! Because of you it is fixed now!!!
Neiko Rivera (Specters) - 답글 공유
Dose anyone know if there is an equivalent guide but for the “Contour +2”?
Christopher Hinrichs - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 42
전체 시간: 1,417
