주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Controller Plate/Buttons Replacement
필요한 것
  1. Controller Plate/Buttons Replacement, Controller Plate/Buttons Replacement: 1 단계, 이미지 1개 중 1개
    • Follow the Prerequisite Guide on how to Replace the Battery to prepare the phone for disassemble. Remove, but do not replace the battery.
    댓글 쓰기
  2. Controller Plate/Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all screws on the plastic case with a T6 Torx T-4 screwdriver, as shown.
    • Blue Circle: T6 Torx, Length 5mm
    • Red Circle: T6 Torx, Length 4mm
    • The screen and other parts are now loose and can easily fall off.
    댓글 쓰기
  3. Controller Plate/Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Separate the back cover from the phone. A plastic removal tool can be used here.
    댓글 쓰기
  4. Controller Plate/Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the last two screws holding the motherboard to the device.
    • Orange Circle: 00 Philips head, Length 2 mm
    댓글 쓰기
  5. Controller Plate/Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull up the motherboard. Some force may need to be applied.
    • Some wires on the reverse side are still attached.
    • Make sure to line up the plastic connectors highlighted by the red circles when re-assembling.
    댓글 쓰기
  6. Controller Plate/Buttons Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Break the break the data cable connection between the motherboard and the controller plate by gently pulling out the connecting wire with tweezers.
    • When the device is orientated as shown in the picture, apply the force parallel to the motherboard and away from the device, as depicted by the red arrows.
    댓글 쓰기
  7. Controller Plate/Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • The entire controller plate should now be free from the phone. All the buttons can now be taken off by gently pressing them out.
    • If the touch-pad joysticks do not work, the entire plate needs to be replaced.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Pieter Boersma
회원 가입일: 03/25/15
455 평판
안내서 3개를 작성함
UMass Dartmouth, Team 7-3, Cichon Spring 2015 UMass Dartmouth, Team 7-3, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G3
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 44
전체 시간: 1,787
