주요 콘텐츠로 건너뛰기
Core Assembly Removal
필요한 것
  1. Core Assembly Removal, Unfasten the screws: 1 단계, 이미지 1개 중 1개
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
  2. Core Assembly Removal, Open the watch: 2 단계, 이미지 2개 중 1개 Core Assembly Removal, Open the watch: 2 단계, 이미지 2개 중 2개
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
  3. Core Assembly Removal, Disconnect the sensor cable: 3 단계, 이미지 2개 중 1개 Core Assembly Removal, Disconnect the sensor cable: 3 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
  4. Core Assembly Removal, Remove the back cover: 4 단계, 이미지 1개 중 1개
    • Remove the back cover.
  5. Core Assembly Removal, Core Assembly Removal: 5 단계, 이미지 1개 중 1개
    • Remove the three 3.7 mm-long Phillips #00 screws.
  6. Core Assembly Removal: 6 단계, 이미지 3개 중 1개 Core Assembly Removal: 6 단계, 이미지 3개 중 2개 Core Assembly Removal: 6 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
    • Use your spudger as a lever and pry up the core assembly.
    • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
  7. Core Assembly Removal: 7 단계, 이미지 2개 중 1개 Core Assembly Removal: 7 단계, 이미지 2개 중 2개
    • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
    • Be careful not to strain the display and sensor flex cables during this procedure.
  8. Core Assembly Removal: 8 단계, 이미지 2개 중 1개 Core Assembly Removal: 8 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
  9. Core Assembly Removal: 9 단계, 이미지 2개 중 1개 Core Assembly Removal: 9 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
  10. Core Assembly Removal: 10 단계, 이미지 1개 중 1개
    • Remove the core assembly.
결론
Repair didn’t go as planned? Check out our Answers community for help.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
247,305 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,738개를 작성함
1가이드 댓글
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
luciano.alonso84@gmail.com - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 18
전체 시간: 1,472
