주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Core Assembly Removal
필요한 것
  1. Core Assembly Removal, Unfasten the back cover screws: 1 단계, 이미지 1개 중 1개
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
    댓글 쓰기
  2. Core Assembly Removal, Wedge open the back cover: 2 단계, 이미지 2개 중 1개 Core Assembly Removal, Wedge open the back cover: 2 단계, 이미지 2개 중 2개
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
    댓글 쓰기
  3. Core Assembly Removal, Disconnect the sensor flex cable: 3 단계, 이미지 3개 중 1개 Core Assembly Removal, Disconnect the sensor flex cable: 3 단계, 이미지 3개 중 2개 Core Assembly Removal, Disconnect the sensor flex cable: 3 단계, 이미지 3개 중 3개
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    댓글 쓰기
  4. Core Assembly Removal, Remove the back cover: 4 단계, 이미지 2개 중 1개 Core Assembly Removal, Remove the back cover: 4 단계, 이미지 2개 중 2개
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
    댓글 쓰기
  5. Core Assembly Removal, Unplug the display connector: 5 단계, 이미지 2개 중 1개 Core Assembly Removal, Unplug the display connector: 5 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
    댓글 쓰기
  6. Core Assembly Removal, Loosen the core assembly: 6 단계, 이미지 2개 중 1개 Core Assembly Removal, Loosen the core assembly: 6 단계, 이미지 2개 중 2개
    • The core's plastic frame fits tightly within the watch's metal housing.
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    댓글 쓰기
  7. Core Assembly Removal, Remove the core assembly: 7 단계, 이미지 3개 중 1개 Core Assembly Removal, Remove the core assembly: 7 단계, 이미지 3개 중 2개 Core Assembly Removal, Remove the core assembly: 7 단계, 이미지 3개 중 3개
    • Carefully thread the display flex cable through the gap on the core's plastic frame.
    • Remove the core assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
Tobias Isakeit
회원 가입일: 03/31/14
133,935 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,151개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 56
전체 시간: 1,612
