주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Corsair Katar Optical Sensor Replacement
필요한 것
  1. Corsair Katar Optical Sensor Replacement, Corsair Katar Disassembly: 1 단계, 이미지 2개 중 1개 Corsair Katar Optical Sensor Replacement, Corsair Katar Disassembly: 1 단계, 이미지 2개 중 2개
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
    댓글 쓰기
  2. Corsair Katar Optical Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
    댓글 쓰기
  3. Corsair Katar Optical Sensor Replacement: 3 단계, 이미지 2개 중 1개 Corsair Katar Optical Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
    댓글 쓰기
  4. Corsair Katar Optical Sensor Replacement: 4 단계, 이미지 1개 중 1개
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
    댓글 쓰기
  5. Corsair Katar Optical Sensor Replacement, Scroll Wheel: 5 단계, 이미지 2개 중 1개 Corsair Katar Optical Sensor Replacement, Scroll Wheel: 5 단계, 이미지 2개 중 2개
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
    댓글 쓰기
  6. Corsair Katar Optical Sensor Replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
    댓글 쓰기
  7. Corsair Katar Optical Sensor Replacement: 7 단계, 이미지 1개 중 1개
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
    댓글 쓰기
  8. Corsair Katar Optical Sensor Replacement, Optical Sensor: 8 단계, 이미지 2개 중 1개 Corsair Katar Optical Sensor Replacement, Optical Sensor: 8 단계, 이미지 2개 중 2개
    • Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
    댓글 쓰기
  9. Corsair Katar Optical Sensor Replacement: 9 단계, 이미지 2개 중 1개 Corsair Katar Optical Sensor Replacement: 9 단계, 이미지 2개 중 2개
    • Desolder the 20 connecting pins to remove the optical sensor.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Margaret Loughren
회원 가입일: 07/12/18
594 평판
안내서 5개를 작성함
UW Tacoma, Team S1-G3, Cardinal Summer 2018 UW Tacoma, Team S1-G3, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G3
3 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 37
전체 시간: 1,520
