주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Corsair Katar Scroll Wheel Sensor
필요한 것
  1. Corsair Katar Scroll Wheel Sensor, Corsair Katar Disassembly: 1 단계, 이미지 2개 중 1개 Corsair Katar Scroll Wheel Sensor, Corsair Katar Disassembly: 1 단계, 이미지 2개 중 2개
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
    댓글 쓰기
  2. Corsair Katar Scroll Wheel Sensor: 2 단계, 이미지 1개 중 1개
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
    댓글 쓰기
  3. Corsair Katar Scroll Wheel Sensor: 3 단계, 이미지 2개 중 1개 Corsair Katar Scroll Wheel Sensor: 3 단계, 이미지 2개 중 2개
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
    댓글 쓰기
  4. Corsair Katar Scroll Wheel Sensor: 4 단계, 이미지 1개 중 1개
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
    댓글 쓰기
  5. Corsair Katar Scroll Wheel Sensor, Scroll Wheel: 5 단계, 이미지 2개 중 1개 Corsair Katar Scroll Wheel Sensor, Scroll Wheel: 5 단계, 이미지 2개 중 2개
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
    댓글 쓰기
  6. Corsair Katar Scroll Wheel Sensor: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
    댓글 쓰기
  7. Corsair Katar Scroll Wheel Sensor: 7 단계, 이미지 1개 중 1개
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
    댓글 쓰기
  8. Corsair Katar Scroll Wheel Sensor, Scroll Wheel Sensor: 8 단계, 이미지 2개 중 1개 Corsair Katar Scroll Wheel Sensor, Scroll Wheel Sensor: 8 단계, 이미지 2개 중 2개
    • Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
    댓글 쓰기
  9. Corsair Katar Scroll Wheel Sensor: 9 단계, 이미지 2개 중 1개 Corsair Katar Scroll Wheel Sensor: 9 단계, 이미지 2개 중 2개
    • Desolder the 5 connecting pins to remove the scroll wheel sensor from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Margaret Loughren
회원 가입일: 07/12/18
594 평판
안내서 5개를 작성함
UW Tacoma, Team S1-G3, Cardinal Summer 2018 UW Tacoma, Team S1-G3, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G3
3 회원들
안내서 13개를 작성함
2가이드 댓글
bonsoir moi ma molette tourne dans le vide rien ne accroche merci
Tara - 답글 공유
Do I need new pads when I take out the old ones or will the same one stick?
Ishaan Patel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 41
전체 시간: 2,271
