주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Corsair Katar USB Cable Replacement
필요한 것
  1. Corsair Katar USB Cable Replacement, Corsair Katar Disassembly: 1 단계, 이미지 2개 중 1개 Corsair Katar USB Cable Replacement, Corsair Katar Disassembly: 1 단계, 이미지 2개 중 2개
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
    댓글 쓰기
  2. Corsair Katar USB Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
    댓글 쓰기
  3. Corsair Katar USB Cable Replacement: 3 단계, 이미지 2개 중 1개 Corsair Katar USB Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
    댓글 쓰기
  4. Corsair Katar USB Cable Replacement: 4 단계, 이미지 1개 중 1개
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
    댓글 쓰기
  5. Corsair Katar USB Cable Replacement, USB Cable: 5 단계, 이미지 2개 중 1개 Corsair Katar USB Cable Replacement, USB Cable: 5 단계, 이미지 2개 중 2개
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
    댓글 쓰기
  6. Corsair Katar USB Cable Replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
    댓글 쓰기
  7. Corsair Katar USB Cable Replacement: 7 단계, 이미지 2개 중 1개 Corsair Katar USB Cable Replacement: 7 단계, 이미지 2개 중 2개
    • Use the JIS 0 screwdriver to remove the 5mm screw attached to the USB wire housing.
    • Lift the USB wire away from the shell of the mouse.
    • When reassembling the device, run the USB wire through the channel on the bottom of the shell to keep it in place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Margaret Loughren
회원 가입일: 07/12/18
594 평판
안내서 5개를 작성함
UW Tacoma, Team S1-G3, Cardinal Summer 2018 UW Tacoma, Team S1-G3, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G3
3 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 48
전체 시간: 1,789
