주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cr-48 Chromebook Network Card Replacement
필요한 것
    1. Cr-48 Chromebook Network Card Replacement, Battery: 1 단계, 이미지 3개 중 1개 Cr-48 Chromebook Network Card Replacement, Battery: 1 단계, 이미지 3개 중 2개 Cr-48 Chromebook Network Card Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • To take out the battery, slide the switch on the bottom of the laptop.
      • The battery should then pop out and you can remove it.
      댓글 쓰기
    1. Cr-48 Chromebook Network Card Replacement, Bottom Casing: 2 단계, 이미지 2개 중 1개 Cr-48 Chromebook Network Card Replacement, Bottom Casing: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
      댓글 쓰기
    2. Cr-48 Chromebook Network Card Replacement: 3 단계, 이미지 3개 중 1개 Cr-48 Chromebook Network Card Replacement: 3 단계, 이미지 3개 중 2개 Cr-48 Chromebook Network Card Replacement: 3 단계, 이미지 3개 중 3개
      • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
      • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
      댓글 쓰기
    3. Cr-48 Chromebook Network Card Replacement: 4 단계, 이미지 3개 중 1개 Cr-48 Chromebook Network Card Replacement: 4 단계, 이미지 3개 중 2개 Cr-48 Chromebook Network Card Replacement: 4 단계, 이미지 3개 중 3개
      • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
      • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
      댓글 쓰기
    1. Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 5 단계, 이미지 3개 중 1개 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 5 단계, 이미지 3개 중 2개 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 5 단계, 이미지 3개 중 3개
      • With the lower case removed, look for the network card. It’s typically located in the corner near one of the USB ports.
      • Use tweezers or forceps to carefully lift off the wire connectors attached to the network card.
      • Take note of which wire went to which terminal (e.g., left vs. right).
      댓글 쓰기
    2. Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 6 단계, 이미지 3개 중 1개 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 6 단계, 이미지 3개 중 2개 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 6 단계, 이미지 3개 중 3개
      • Remove the single 3 mm screw securing the network card to the board.
      • Once the screw is out, the card should pivot upward slightly (“pop up”).
      • Gently pull the network card out of its socket at an angle and remove it completely.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an E-Waste certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Robert McLaughlin
회원 가입일: 09/09/14
471 평판
안내서 3개를 작성함
CSU Fullerton, Team 2-2, Bruce Fall 2014 CSU Fullerton, Team 2-2, Bruce Fall 2014 회원
CSUF-BRUCE-F14S2G2
3 회원들
안내서 10개를 작성함
1가이드 댓글
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
Jorge Gomes - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 30
전체 시간: 1,474
