주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creating Apple Lisa KeyCaps
필요한 것
  1. Creating Apple Lisa KeyCaps, Selecting Keys: 1 단계, 이미지 2개 중 1개 Creating Apple Lisa KeyCaps, Selecting Keys: 1 단계, 이미지 2개 중 2개
    • My keyboard was missing a variety of keys so I needed to select source keys to create the molds. On the 2nd image all the like-keys are color-coded.
    댓글 쓰기
  2. Creating Apple Lisa KeyCaps, Base Mold: 2 단계, 이미지 1개 중 1개
    • Mix enough putty that the source key will fit in. Make sure the edge of the key is flush with the top of the putty to ensure the key is the correct size.
    댓글 쓰기
  3. Creating Apple Lisa KeyCaps, Connector Mold: 3 단계, 이미지 1개 중 1개
    • Once the base mold is set, mix a tiny amount of putty to press down into the key. Unseen in this photo: press the putty down right to the pegs of the source key so they are poking holes in the top of the mold.
    댓글 쓰기
    • Put on a pair of disposable rubber gloves or you’ll be peeling off the resin from your fingers for weeks.
    댓글 쓰기
  4. Creating Apple Lisa KeyCaps, Casting: 5 단계, 이미지 1개 중 1개
    • Mix a tiny amount of resin as directed on the bottle. Ensure you are measuring accurately. Pour the resin into the base mold until 3/4th filled. Put the top mold on top of the base mold as to cast the connector onto the mold. Unseen in this photo is the correct top mold with the exposed holes on top. Pour liquid resin into the top to fill the holes
    댓글 쓰기
  5. Creating Apple Lisa KeyCaps, Setting Up: 6 단계, 이미지 1개 중 1개
    • After about half an hour remove the key from the mold and set aside to finish setting up. Be careful not to snap the connectors off when removing from mold. Sand off the edges if needed.
    댓글 쓰기
  6. Creating Apple Lisa KeyCaps, Painting: 7 단계, 이미지 1개 중 1개
    • Once the key(s) have set up, you can now paint. Be careful not to overpaint which will lead to the key being too thick.
    댓글 쓰기
  7. Creating Apple Lisa KeyCaps, Fitting: 8 단계, 이미지 1개 중 1개
    • Assemble the keys to ensure they work before writing the key symbols. If you need replacement springs, I suggest the spring kit (listed in the parts section.) it has 8 useable springs per kit for this kind of project.
    댓글 쓰기
  8. Creating Apple Lisa KeyCaps, Key Symbols: 9 단계, 이미지 1개 중 1개
    • Once you are happy with the keys, use a fine tip sharpie to write the key symbols. Let the sharpie dry for a day.
    댓글 쓰기
결론
While crude, they work quite well especially after you spend a huge amount of time online realizing there are no places to buy replacement keycaps.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
LisaGuide
회원 가입일: 12/30/18
1,833 평판
안내서 11개를 작성함
1가이드 댓글
No, the results are unfortunately not convincing (sorry to say that). Maybe it is better using a 3D printer for this ...?
Peter Mueller - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 42
전체 시간: 949
