주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creative Zen Vision M Battery Replacement
필요한 것
    1. Creative Zen Vision M Battery  Replacement, Opening the top: 1 단계, 이미지 2개 중 1개 Creative Zen Vision M Battery  Replacement, Opening the top: 1 단계, 이미지 2개 중 2개
      • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
      • Unscrew and remove the two exposed Phillips head screws
      댓글 쓰기
    2. Creative Zen Vision M Battery  Replacement, Opening the device: 2 단계, 이미지 2개 중 1개 Creative Zen Vision M Battery  Replacement, Opening the device: 2 단계, 이미지 2개 중 2개
      • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
      • Don't try attempt to open it from the recess between the buttons and the device.
      댓글 쓰기
    3. Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: 3 단계, 이미지 3개 중 1개 Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: 3 단계, 이미지 3개 중 2개 Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: 3 단계, 이미지 3개 중 3개
      • To detach wires from the screen, gently tug on the wires connected to the battery. They are located on the bottom half of the screen.
      댓글 쓰기
    4. Creative Zen Vision M Battery  Replacement, Releasing the battery: 4 단계, 이미지 1개 중 1개
      • To begin removing the battery, move the wires out from under the black foam at the bottom of the device
      댓글 쓰기
    5. Creative Zen Vision M Battery  Replacement, Removing the battery: 5 단계, 이미지 2개 중 1개 Creative Zen Vision M Battery  Replacement, Removing the battery: 5 단계, 이미지 2개 중 2개
      • Use a plastic opening tool or nylon spudger to lift up the battery.
      • Battery may be glued on the edges.
      • The metal spudger is great for serious prying power, but the regular black nylon spudger should be used whenever possible, especially around batteries.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Kirstie G
회원 가입일: 10/12/16
491 평판
안내서 4개를 작성함
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G1
4 회원들
안내서 36개를 작성함
4가이드 댓글
Step 1 does not mention that the bottom cover needs to also be removed to access two more screws. Make note of the screw lengths and where they come from.. Two are shorter.
Bob Terwilliger - 답글 공유
Seconding this, if you try to separate the top and bottom covers before unscrewing the two screws to the sides of the charging/data port you may damage your device irreparably. In my case I had already watched a guide online and I did not damage mine, but after so many years the plastic has degraded and it's very easy to see how you could do some serious damage if you're not careful.
valpampa - 답글 공유
Does anyone know, what do you do if the existing battery goes completely flat, and the unit will not charge. I believe the battery needs replacing. Are these batteries available, and if they do, what is the shelf life of a new battery?
Carl MacCulloch - 답글 공유
Note that last Vision:M firmware's versions are not compatible with most third-party batteries, especially those with a capacity different than 1400mAh. The symptoms are a battery that is always recognized to be empty and that doesn't charge at all. If it is you case, you need to downgrade to firmware 1.41.01 (or remplace the battery controller board ...). See eg https://www.reddit.com/r/DHExchange/comm...
Roland - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 39
지난 30일: 128
전체 시간: 7,595
