주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creative Zen Vision M Hard-drive Replacement
필요한 것
    1. Creative Zen Vision M Hard-drive Replacement, Opening the top: 1 단계, 이미지 2개 중 1개 Creative Zen Vision M Hard-drive Replacement, Opening the top: 1 단계, 이미지 2개 중 2개
      • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
      • Unscrew and remove the two exposed Phillips head screws.
      • Do the same for the bottom plastic surrounding the bottom connector, as there are two screws under here as well.
      댓글 쓰기
    2. Creative Zen Vision M Hard-drive Replacement, Opening the device: 2 단계, 이미지 2개 중 1개 Creative Zen Vision M Hard-drive Replacement, Opening the device: 2 단계, 이미지 2개 중 2개
      • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
      • Don't try attempt to open it from the recess between the buttons and the device.
      댓글 쓰기
    3. Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 3 단계, 이미지 3개 중 1개 Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 3 단계, 이미지 3개 중 2개 Creative Zen Vision M Hard-drive Replacement, Disconnecting from the screen: 3 단계, 이미지 3개 중 3개
      • To detach wires from the screen, gently tug on the wires connected to the battery. They are located on the bottom half of the screen.
      댓글 쓰기
    4. Creative Zen Vision M Hard-drive Replacement, Disconnecting the hard drive: 4 단계, 이미지 1개 중 1개
      • Pull black hard drive connector located at the top right.
      • Ensure, as demonstrated by the image, that the screen is safely removed first. There is an iFixit guide showing how to carefully pull apart the Creative Zen Vision M.
      댓글 쓰기
    5. Creative Zen Vision M Hard-drive Replacement, Removing bumpers: 5 단계, 이미지 1개 중 1개
      • Pull off blue bumpers and connect to new hard drive
      댓글 쓰기
    6. Creative Zen Vision M Hard-drive Replacement, Removing hard drive connector: 6 단계, 이미지 2개 중 1개 Creative Zen Vision M Hard-drive Replacement, Removing hard drive connector: 6 단계, 이미지 2개 중 2개
      • Lift white flap on top of hard drive to disconnect hard drive connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Kirstie G
회원 가입일: 10/12/16
491 평판
안내서 4개를 작성함
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G1
4 회원들
안내서 40개를 작성함
3가이드 댓글
How do you get the firmware on the new hard drive?
Selvedge - 답글 공유
Download the firmware software from: http://support.creative.com/Downloads/we...
(Select firmware).
Then:
Close all application windows that are currently running on your computer.
Connect your player to your computer.
Double-click the downloaded file and follow the instructions on the screen.
Regards.
Brendan Eager - 답글 공유
I should also update the link provided. Here’s a slightly better link. Select “Zen Series” then your specific model. To flash the firmware on the new hard drive. Download the file into your local hard disk. Close all application windows that are currently running on your computer. Connect your player to your computer (with the included adapter and USB wire). Double-click the downloaded file and follow the instructions on the screen.
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 75
전체 시간: 5,364
