주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creative Zen Vision M Screen Replacement
필요한 것
    1. Creative Zen Vision M Screen Replacement, Opening the top: 1 단계, 이미지 2개 중 1개 Creative Zen Vision M Screen Replacement, Opening the top: 1 단계, 이미지 2개 중 2개
      • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
      • Unscrew and remove the two exposed Phillips head screws.
      댓글 쓰기
    2. Creative Zen Vision M Screen Replacement, Opening the device: 2 단계, 이미지 2개 중 1개 Creative Zen Vision M Screen Replacement, Opening the device: 2 단계, 이미지 2개 중 2개
      • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
      • Don't try attempt to open it from the recess between the buttons and the device.
      댓글 쓰기
    3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: 3 단계, 이미지 3개 중 1개 Creative Zen Vision M Screen Replacement, Disconnecting the battery: 3 단계, 이미지 3개 중 2개 Creative Zen Vision M Screen Replacement, Disconnecting the battery: 3 단계, 이미지 3개 중 3개
      • Disconnect the wire from the bottom device.
      • Handle with care as the wires tend to disconnect easily.
      댓글 쓰기
    4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: 4 단계, 이미지 1개 중 1개
      • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
      • Handle with care as the hard drive also comes off easily.
      댓글 쓰기
    5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: 5 단계, 이미지 1개 중 1개
      • Unscrew the seven screws placed around the mother board.
      • You will need a one millimeter Phillips head screwdriver.
      • The screws are small, so keep them safely.
      댓글 쓰기
    6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 6 단계, 이미지 3개 중 1개 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 6 단계, 이미지 3개 중 2개 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: 6 단계, 이미지 3개 중 3개
      • Flip your device upside down so that the motherboard will loosen.
      • Detach the connector from the motherboard.
      댓글 쓰기
    7. Creative Zen Vision M Screen Replacement, Removing the screen: 7 단계, 이미지 2개 중 1개 Creative Zen Vision M Screen Replacement, Removing the screen: 7 단계, 이미지 2개 중 2개
      • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
      • Lift the light gray flap to detach the screen from the motherboard.
      댓글 쓰기
    8. Creative Zen Vision M Screen Replacement, Seperating the digital display: 8 단계, 이미지 2개 중 1개 Creative Zen Vision M Screen Replacement, Seperating the digital display: 8 단계, 이미지 2개 중 2개
      • Separate the clear screen frame from the digital display.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Kirstie G
회원 가입일: 10/12/16
491 평판
안내서 4개를 작성함
Texas Tech, Team 12-1, Bennett Fall 2016 Texas Tech, Team 12-1, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G1
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 54
전체 시간: 2,019
