주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creative Zen X-Fi LCD Screen Replacement
필요한 것
    1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: 1 단계, 이미지 3개 중 1개 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: 1 단계, 이미지 3개 중 2개 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: 1 단계, 이미지 3개 중 3개
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      댓글 쓰기
    1. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: 2 단계, 이미지 1개 중 1개
      • The black rubber button pad can be removed by simply picking it up.
      댓글 쓰기
    1. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: 3 단계, 이미지 1개 중 1개
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      댓글 쓰기
    2. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: 4 단계, 이미지 1개 중 1개
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      댓글 쓰기
    1. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: 5 단계, 이미지 1개 중 1개
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      댓글 쓰기
    2. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: 6 단계, 이미지 1개 중 1개
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      댓글 쓰기
    3. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: 7 단계, 이미지 1개 중 1개
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      댓글 쓰기
    1. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: 8 단계, 이미지 2개 중 1개 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: 8 단계, 이미지 2개 중 2개
      • Lift the right edge of the motherboard off the back case.
      • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
      댓글 쓰기
    1. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: 9 단계, 이미지 2개 중 1개 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: 9 단계, 이미지 2개 중 2개
      • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
      댓글 쓰기
    2. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: 10 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
      • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 71
전체 시간: 2,080
