주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creative Ziio 7" Camera Replacement
필요한 것
  1. Creative Ziio 7" Camera Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Creative Ziio 7" Camera Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Creative Ziio 7" Camera Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
    댓글 쓰기
  2. Creative Ziio 7" Camera Replacement, Camera: 2 단계, 이미지 3개 중 1개 Creative Ziio 7" Camera Replacement, Camera: 2 단계, 이미지 3개 중 2개 Creative Ziio 7" Camera Replacement, Camera: 2 단계, 이미지 3개 중 3개
    • Unscrew the four 3mm Phillips #00 screws found in each corner of the motherboard.
    댓글 쓰기
  3. Creative Ziio 7" Camera Replacement: 3 단계, 이미지 3개 중 1개 Creative Ziio 7" Camera Replacement: 3 단계, 이미지 3개 중 2개 Creative Ziio 7" Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Unplug the ribbon cable near the edge of the motherboard in the bottom right of the device.
    댓글 쓰기
  4. Creative Ziio 7" Camera Replacement: 4 단계, 이미지 2개 중 1개 Creative Ziio 7" Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Lift up the motherboard.
    • A mesh-like strip on the right side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip. Use tweezers or pliers to pull on the strip and unplug it.
    댓글 쓰기
  5. Creative Ziio 7" Camera Replacement: 5 단계, 이미지 2개 중 1개 Creative Ziio 7" Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Lift up the motherboard and locate the ribbon cable (burnt orange-colored strip) centered on top of the motherboard.
    • The ribbon cable with the attached camera is plugged into the motherboard.
    • Unplug the ribbon cable using your fingers to pull up on the flap.
    댓글 쓰기
  6. Creative Ziio 7" Camera Replacement: 6 단계, 이미지 2개 중 1개 Creative Ziio 7" Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Use a spudger to pry the camera away from the rubber camera mount.
    • Do not remove the entire rubber camera mount. Only remove the camera attached with adhesive.
    • Remove the broken camera and use electronic-friendly adhesive to attach a new camera.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Kendall Ruggles
회원 가입일: 04/16/13
35 평판
안내서 1개를 작성함
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 회원
CPSU-MANESS-S13S14G10
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 30
전체 시간: 745
