주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creative Ziio 7" LCD Screen Replacement
필요한 것
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Creative Ziio 7" LCD Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Creative Ziio 7" LCD Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
    댓글 쓰기
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: 2 단계, 이미지 1개 중 1개
    • Remove the four 3mm Philips #00 screws around the large silver battery.
    댓글 쓰기
  3. Creative Ziio 7" LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
    댓글 쓰기
  4. Creative Ziio 7" LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 Creative Ziio 7" LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 Creative Ziio 7" LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
    댓글 쓰기
  5. Creative Ziio 7" LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
    댓글 쓰기
  6. Creative Ziio 7" LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
    댓글 쓰기
  7. Creative Ziio 7" LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Creative Ziio 7" LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
    댓글 쓰기
  8. Creative Ziio 7" LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully remove the black LCD screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Kyle
회원 가입일: 04/16/13
126 평판
안내서 2개를 작성함
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 회원
CPSU-MANESS-S13S14G10
4 회원들
안내서 15개를 작성함
2가이드 댓글
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - 답글 공유
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 35
전체 시간: 1,771
