주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Creative Ziio 7" Motherboard Replacement
필요한 것
  1. Creative Ziio 7" Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Creative Ziio 7" Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Creative Ziio 7" Motherboard Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
    댓글 쓰기
  2. Creative Ziio 7" Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 1개 Creative Ziio 7" Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 2개 Creative Ziio 7" Motherboard Replacement, Motherboard: 2 단계, 이미지 3개 중 3개
    • Remove the copper plate covering the motherboard by desoldering the ten solder points.
    • The solder point in the bottom right corner is marked but hidden by the soldering iron.
    댓글 쓰기
  3. Creative Ziio 7" Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Creative Ziio 7" Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the motherboard.
    댓글 쓰기
  4. Creative Ziio 7" Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Creative Ziio 7" Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Creative Ziio 7" Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Disconnect the ribbon cable that is attached underneath the copper plate.
    • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
    댓글 쓰기
  5. Creative Ziio 7" Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Creative Ziio 7" Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
    • The copper plate will be removed by now. However, the picture does not show this.
    댓글 쓰기
  6. Creative Ziio 7" Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Creative Ziio 7" Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift up the motherboard.
    • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
    댓글 쓰기
  7. Creative Ziio 7" Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
    • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
    댓글 쓰기
  8. Creative Ziio 7" Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the old motherboard and dispose of it resposibly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Benedict Samoy
회원 가입일: 04/16/13
34 평판
안내서 2개를 작성함
Cal Poly, Team 14-10, Maness Spring 2013 Cal Poly, Team 14-10, Maness Spring 2013 회원
CPSU-MANESS-S13S14G10
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 19
전체 시간: 1,448
