주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cricut Maker Motherboard Replacement
필요한 것
    1. Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: 1 단계, 이미지 3개 중 3개
      • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
      • Applying too much pressure to this can break it as it is very fragile.
      • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
      • Remove the cover from the connecting joint and set it aside.
      댓글 쓰기
    2. Cricut Maker Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Cricut Maker Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
      댓글 쓰기
    3. Cricut Maker Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Turn the device around, so that the back is facing you.
      • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
      • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
      • These actions should reveal the cylindrical connectors.
      댓글 쓰기
    4. Cricut Maker Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Press down on the lid.
      • Push the lid outwards to free it from the jointed clasps.
      댓글 쓰기
    1. Cricut Maker Motherboard Replacement, Front Door Replacement: 5 단계, 이미지 2개 중 1개 Cricut Maker Motherboard Replacement, Front Door Replacement: 5 단계, 이미지 2개 중 2개
      • Using your hands or an opening tool, remove the four foot pads covering four screws.
      • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
      댓글 쓰기
    2. Cricut Maker Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
      • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
      • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
      댓글 쓰기
    3. Cricut Maker Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement: 7 단계, 이미지 3개 중 3개
      • Turn the device on its side.
      • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
      댓글 쓰기
    4. Cricut Maker Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement: 8 단계, 이미지 3개 중 3개
      • Lift the top case off of the base of the device.
      • After removing this cover, the internals of the device will be exposed.
      댓글 쓰기
    5. Cricut Maker Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Cricut Maker Motherboard Replacement: 9 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
      • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
      댓글 쓰기
    6. Cricut Maker Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement: 10 단계, 이미지 3개 중 3개
      • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
      • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
      댓글 쓰기
    7. Cricut Maker Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Cricut Maker Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
      댓글 쓰기
    8. Cricut Maker Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Cricut Maker Motherboard Replacement: 12 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
      • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
      댓글 쓰기
    9. Cricut Maker Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement: 13 단계, 이미지 3개 중 3개
      • Remove a total of seven 10 mm screws from the underside of the door.
      • One side of the base has two 10mm screws.
      • The other side of the base has five 10 mm screws.
      댓글 쓰기
    10. Cricut Maker Motherboard Replacement: 14 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement: 14 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement: 14 단계, 이미지 3개 중 3개
      • Pry the door from hinges using an iFixit opening tool.
      • Lift upwards and towards you, to remove the door from the hinges.
      댓글 쓰기
    1. Cricut Maker Motherboard Replacement, Motherboard Replacement: 15 단계, 이미지 3개 중 1개 Cricut Maker Motherboard Replacement, Motherboard Replacement: 15 단계, 이미지 3개 중 2개 Cricut Maker Motherboard Replacement, Motherboard Replacement: 15 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove the five 7 mm screws from the motherboard.
      댓글 쓰기
    2. Cricut Maker Motherboard Replacement: 16 단계, 이미지 1개 중 1개
      • Remove the gray electrical tape from the cables.
      댓글 쓰기
    3. Cricut Maker Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Cricut Maker Motherboard Replacement: 17 단계, 이미지 2개 중 2개
      • Unplug both cables from the corners of the motherboard by pulling them upwards from the base of the connectors.
      댓글 쓰기
    4. Cricut Maker Motherboard Replacement: 18 단계, 이미지 2개 중 1개 Cricut Maker Motherboard Replacement: 18 단계, 이미지 2개 중 2개
      • Gently slide the motherboard out from USB port slot to remove it from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Devyn White
회원 가입일: 09/20/22
1,161 평판
안내서 5개를 작성함
Austin Community College, Team 9-1, Watkins Fall 2022 Austin Community College, Team 9-1, Watkins Fall 2022 회원
AUSTINCC-WATKINS-F22S9G1
3 회원들
안내서 27개를 작성함
11가이드 댓글
So do you sell the motherboard or know where it buy one for cricut cxpl301
David Washington - 답글 공유
I too am looking for a replacement board. It was suggested to me that I could contact one of the pcb repair companies. For a fee, they will either check and repair your board or they will copy and print a new board and mail it back to you. You have to send in your board for them to check and copy though. So I guess reputation and reviews would be priority. It would suck to send our boards off and never receive a new one or the old one. :-/.
Jennifer Daniels - 답글 공유
Cricut does not sell parts. Cricut does not do repairs.
B·Ware - 답글 공유
sooooo, theres no place to get parts? thats stupid...might as well just through it away then...
Kirk Serbian - 답글 공유
Bonjour pourriez vous nous dire où trouver la carte mère svp
Magali Magnier - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 42
지난 30일: 236
전체 시간: 12,297
