주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Crock-Pot Express Crock Multi-Cooker Heating Element Replacement
필요한 것
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Power Cord: 1 단계, 이미지 1개 중 1개
      • Remove the power cord from the wall outlet first, disconnecting power from the device.
      댓글 쓰기
    2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 2 단계, 이미지 1개 중 1개
      • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
      댓글 쓰기
    3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 3 단계, 이미지 2개 중 1개 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 3 단계, 이미지 2개 중 2개
      • Grasp the power cord input connector firmly with forefinger and thumb.
      • Without tugging, apply pulling force until the connector is free from device
      댓글 쓰기
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: 4 단계, 이미지 3개 중 1개 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: 4 단계, 이미지 3개 중 2개 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: 4 단계, 이미지 3개 중 3개
      • Orient the crock pot where the lid locked and unlocked icons are visible.
      • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
      • Remove the lid.
      댓글 쓰기
    1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Heating Element: 5 단계, 이미지 1개 중 1개
      • Remove the inner pot and set it aside for reassembly.
      댓글 쓰기
    2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 6 단계, 이미지 1개 중 1개
      • Carefully rotate the Crock-Pot so that the bottom is facing upward, allowing access to the electrical panel.
      • Remove the two 12.4 mm screws with a Phillips #2 screwdriver.
      댓글 쓰기
    3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 7 단계, 이미지 1개 중 1개
      • Rotate the electrical panel cover counter clockwise and pull up until the panel comes free.
      댓글 쓰기
    4. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 8 단계, 이미지 2개 중 1개 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 8 단계, 이미지 2개 중 2개
      • Remove 3 nuts, 3 washers, 3 spacers, and 3 lock washers using an adjustable wrench to free the heating element from the Crock-Pot housing.
      댓글 쓰기
    5. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the 10mm screw and metal plate beneath the electrical nodes using a Phillips #2 screwdriver.
      댓글 쓰기
    6. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the 2 red wires from the terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as red.
      • Remove 1 white wire from terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as white.
      댓글 쓰기
    7. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 11 단계, 이미지 1개 중 1개
      • Reorient the crockpot on its side to prepare for the heating element removal.
      댓글 쓰기
    8. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 12 단계, 이미지 1개 중 1개
      • Carefully pull the heating element out and rotate it until bottom side is facing up out of the pot.
      댓글 쓰기
    9. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 13 단계, 이미지 2개 중 1개 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: 13 단계, 이미지 2개 중 2개
      • Remove both 19mm screws from the cutout switch housing using a Phillips #2 screwdriver, freeing the heating element from the device.
      • Carefully remove the heating element from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
2가이드 댓글
where do you get a heating element?
Stephanie Brown - 답글 공유
Ma machine j'ai acheté neuf et elle s'allume pas
MOHAMED DJA YAHIA - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 58
전체 시간: 6,096
