주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cuisinart Griddler GR- 4N Button Spring Replacement
필요한 것
  1. Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: 1 단계, 이미지 2개 중 1개 Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: 1 단계, 이미지 2개 중 2개
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
    댓글 쓰기
  2. Cuisinart Griddler GR- 4N Button Spring Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
    댓글 쓰기
  3. Cuisinart Griddler GR- 4N Button Spring Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
    댓글 쓰기
  4. Cuisinart Griddler GR- 4N Button Spring Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
    댓글 쓰기
  5. Cuisinart Griddler GR- 4N Button Spring Replacement: 5 단계, 이미지 2개 중 1개 Cuisinart Griddler GR- 4N Button Spring Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
    댓글 쓰기
  6. Cuisinart Griddler GR- 4N Button Spring Replacement, Button Spring: 6 단계, 이미지 1개 중 1개
    • Depress one of the gray tabs on the side of the housing.
    댓글 쓰기
  7. Cuisinart Griddler GR- 4N Button Spring Replacement: 7 단계, 이미지 1개 중 1개
    • Pull out the black button and the spring will also come out within it.
    댓글 쓰기
  8. Cuisinart Griddler GR- 4N Button Spring Replacement: 8 단계, 이미지 1개 중 1개
    • Pull out the spring, and insert the replacement spring making sure it is correctly aligned.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Laine Aro
회원 가입일: 04/11/16
173 평판
안내서 1개를 작성함
Cal Poly, Team 1-12, Maness Spring 2016 Cal Poly, Team 1-12, Maness Spring 2016 회원
CPSU-MANESS-S16S1G12
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 50
전체 시간: 4,635
