주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
D-Link EBR-2310 LED Light Replacement
필요한 것
  1. D-Link EBR-2310 LED Light Replacement, Remove Plastic Screw Coverings: 1 단계, 이미지 1개 중 1개
    • Begin by placing the wired router face down.
    • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
    • The two bottom plastic screw coverings do not need to be taken off.
    댓글 쓰기
  2. D-Link EBR-2310 LED Light Replacement, Remove Screws: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the two top screws.
    댓글 쓰기
  3. D-Link EBR-2310 LED Light Replacement, Pry Open The Router: 3 단계, 이미지 1개 중 1개
    • Use a plastic opening tool between the edges of the router and gently pry the device apart.
    • Release the clips as you work your way around the device to avoid breaking them.
    • Separate the front and back case of the router.
    댓글 쓰기
  4. D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: 4 단계, 이미지 2개 중 1개 D-Link EBR-2310 LED Light Replacement, Remove Silver Casing: 4 단계, 이미지 2개 중 2개
    • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
    • It should easily snap out of place.
    댓글 쓰기
  5. D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: 5 단계, 이미지 2개 중 1개 D-Link EBR-2310 LED Light Replacement, Remove Inner Bottom Screws: 5 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
    댓글 쓰기
  6. D-Link EBR-2310 LED Light Replacement, Remove Bottom Case: 6 단계, 이미지 1개 중 1개
    • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
    • You have now removed the logic board from your device.
    댓글 쓰기
  7. D-Link EBR-2310 LED Light Replacement, Locate Problematic LED light: 7 단계, 이미지 1개 중 1개
    • Locate the problematic LED light on the motherboard.
    • Using a plastic opening tool, very gently tilt its black base backwards.
    댓글 쓰기
  8. D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: 8 단계, 이미지 2개 중 1개 D-Link EBR-2310 LED Light Replacement, Continue Readjusting LED Light Base: 8 단계, 이미지 2개 중 2개
    • Using your soft finger, tilt the LED light base backwards so that the actual light is facing upside down, at a 180 degree angle from the others.
    댓글 쓰기
  9. D-Link EBR-2310 LED Light Replacement, Remove the LED Light: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • With a pair of tweezers, gently pry the LED light back and forth between its connecting wires until it is able to be removed.
    댓글 쓰기
  10. D-Link EBR-2310 LED Light Replacement, Complete Removal: 10 단계, 이미지 1개 중 1개
    • You should now have a removed LED light, ready to be replaced with a new one.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jessica
회원 가입일: 09/19/14
428 평판
안내서 3개를 작성함
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G4
4 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 28
전체 시간: 705
