주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DBPOWER RD-810 Lens Replacement
필요한 것
    1. DBPOWER RD-810 Lens Replacement, Top Cover: 1 단계, 이미지 2개 중 1개 DBPOWER RD-810 Lens Replacement, Top Cover: 1 단계, 이미지 2개 중 2개
      • Make sure the projector is unplugged before starting
      • Place the projector upside down to access the screws on the bottom.
      • Remove the five 7mm long screws using a #3 Phillips screwdriver at least 2 inches long.
      댓글 쓰기
    2. DBPOWER RD-810 Lens Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the projector over and then remove the cover by lifting it up.
      댓글 쓰기
    1. DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: 3 단계, 이미지 3개 중 1개 DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: 3 단계, 이미지 3개 중 2개 DBPOWER RD-810 Lens Replacement, Motherboard and LED Bulb: 3 단계, 이미지 3개 중 3개
      • Remove the three 6mm PH2 phillips head screws.
      • Disconnect the ribbon cable by flipping up the latch on the connector and then pull the ribbon out.
      댓글 쓰기
    2. DBPOWER RD-810 Lens Replacement: 4 단계, 이미지 3개 중 1개 DBPOWER RD-810 Lens Replacement: 4 단계, 이미지 3개 중 2개 DBPOWER RD-810 Lens Replacement: 4 단계, 이미지 3개 중 3개
      • Disconnect the three wire connectors. Grasp both sides of the connector and pull apart.
      • Keep the connector parallel to the mother board to avoid breaking the solder connection.
      • Lift the motherboard up and place it out of the way.
      댓글 쓰기
    3. DBPOWER RD-810 Lens Replacement: 5 단계, 이미지 3개 중 1개 DBPOWER RD-810 Lens Replacement: 5 단계, 이미지 3개 중 2개 DBPOWER RD-810 Lens Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the five 7mm PH2 phillips head screws on the black plate and lift the plate out.
      • Lift the aluminum heat sink up to remove it from the projector.
      • The motherboard is already removed in this step.
      댓글 쓰기
    1. DBPOWER RD-810 Lens Replacement, Power Supply Circuit: 6 단계, 이미지 3개 중 1개 DBPOWER RD-810 Lens Replacement, Power Supply Circuit: 6 단계, 이미지 3개 중 2개 DBPOWER RD-810 Lens Replacement, Power Supply Circuit: 6 단계, 이미지 3개 중 3개
      • Remove the two 9mm PH2 phillips head screws.
      • Lift the mirror behind the power supply circuit out to gain access to the circuit board.
      댓글 쓰기
    2. DBPOWER RD-810 Lens Replacement: 7 단계, 이미지 2개 중 1개 DBPOWER RD-810 Lens Replacement: 7 단계, 이미지 2개 중 2개
      • Lift the power supply circuit board out of the projector.
      • Disconnect the cable connector by pulling the two sides of the connector apart.
      • Keep the connector parallel to the circuit board to avoid breaking the solder connection.
      댓글 쓰기
    1. DBPOWER RD-810 Lens Replacement, Lens: 8 단계, 이미지 3개 중 1개 DBPOWER RD-810 Lens Replacement, Lens: 8 단계, 이미지 3개 중 2개 DBPOWER RD-810 Lens Replacement, Lens: 8 단계, 이미지 3개 중 3개
      • Flip the projector over and remove the two 6mm PH2 phillips head screws.
      • Flip the projector over so that the opening is facing up.
      • Lift the lens up slightly and then move it towards the interior of the projector before lifting it up and out of the way.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
John Russell
회원 가입일: 02/14/18
941 평판
안내서 9개를 작성함
USF Tampa, Team S5-G3, Eyestone Spring 2018 USF Tampa, Team S5-G3, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G3
3 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 888
