주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DJI Mavic Pro GPS Module Replacement
필요한 것
    1. DJI Mavic Pro GPS Module Replacement, Battery: 1 단계, 이미지 3개 중 1개 DJI Mavic Pro GPS Module Replacement, Battery: 1 단계, 이미지 3개 중 2개 DJI Mavic Pro GPS Module Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      댓글 쓰기
    1. DJI Mavic Pro GPS Module Replacement, Upper Shell: 2 단계, 이미지 1개 중 1개
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      댓글 쓰기
    2. DJI Mavic Pro GPS Module Replacement: 3 단계, 이미지 1개 중 1개
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      댓글 쓰기
    3. DJI Mavic Pro GPS Module Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      댓글 쓰기
    4. DJI Mavic Pro GPS Module Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      댓글 쓰기
    5. DJI Mavic Pro GPS Module Replacement: 6 단계, 이미지 1개 중 1개
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      댓글 쓰기
    6. DJI Mavic Pro GPS Module Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      댓글 쓰기
    1. DJI Mavic Pro GPS Module Replacement, GPS Module: 8 단계, 이미지 1개 중 1개
      • Flip the upper shell over so the metallic plate is facing up.
      • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
      • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
      댓글 쓰기
    2. DJI Mavic Pro GPS Module Replacement: 9 단계, 이미지 1개 중 1개
      • Pry the metallic plate up from the upper shell by using a nylon spudger.
      • Remove the metallic plate from the upper shell by lifting the plate up and out.
      • You may hear a popping sound when prying the metallic plate, but no damage will occur.
      댓글 쓰기
    3. DJI Mavic Pro GPS Module Replacement: 10 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to remove the GPS Module from the upper shell.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kyle Kelser
회원 가입일: 10/08/18
644 평판
안내서 2개를 작성함
Cal Poly, Team S17-G3, White Fall 2018 Cal Poly, Team S17-G3, White Fall 2018 회원
CPSU-WHITE-F18S17G3
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 82
전체 시간: 10,595
