주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DJI Phantom 2 Vision Battery Replacement
필요한 것
  1. DJI Phantom 2 Vision Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
    • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
    댓글 쓰기
  2. DJI Phantom 2 Vision Battery Replacement: 2 단계, 이미지 2개 중 1개 DJI Phantom 2 Vision Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
    댓글 쓰기
  3. DJI Phantom 2 Vision Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
    • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Dylan Ponder
회원 가입일: 09/15/24
386 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 46
전체 시간: 399
