주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement
필요한 것
    1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Remove the four screws with a Torx T8 screwdriver to access the back con board.
      댓글 쓰기
    2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 2 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 2 단계, 이미지 2개 중 2개
      • Remove three screws using a Phillips #00 screwdriver.
      댓글 쓰기
    3. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 3 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • With tweezers, gently remove the large con board tab.
      • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
      댓글 쓰기
    4. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 4 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 4 단계, 이미지 2개 중 2개
      • Peel off the rubber grips to access the screw holes.
      • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
      • Remove the back board and set it aside.
      댓글 쓰기
    5. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 5 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 5 단계, 이미지 2개 중 2개
      • Pull apart the back plastic panel.
      • Recommended tool for this would be the metal spudger, but not required.
      • Once the back panel is off, you will have access to the motherboard.
      댓글 쓰기
    1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: 6 단계, 이미지 2개 중 1개 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: 6 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
      댓글 쓰기
    2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: 7 단계, 이미지 1개 중 1개
      • Remove back buttons and replace with new ones.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Angel Cortez
회원 가입일: 10/02/18
246 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 45
전체 시간: 829
