주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DJI Phantom Case Top Shell Replacement
필요한 것
    1. DJI Phantom Case Top Shell Replacement, Open the Battery Compartment: 1 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Open the Battery Compartment: 1 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Open the Battery Compartment: 1 단계, 이미지 3개 중 3개
      • Press down on battery door release tab to flip the battery door open.
      댓글 쓰기
    2. DJI Phantom Case Top Shell Replacement, Remove the Battery: 2 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Remove the Battery: 2 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Remove the Battery: 2 단계, 이미지 3개 중 3개
      • Pull out the battery pack.
      • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
      댓글 쓰기
    3. DJI Phantom Case Top Shell Replacement, Disconnect the Battery: 3 단계, 이미지 2개 중 1개 DJI Phantom Case Top Shell Replacement, Disconnect the Battery: 3 단계, 이미지 2개 중 2개
      • Pull the two halves of the XT60 power connector apart.
      • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
      댓글 쓰기
    1. DJI Phantom Case Top Shell Replacement, Identifying Silver and Black Collets: 4 단계, 이미지 2개 중 1개 DJI Phantom Case Top Shell Replacement, Identifying Silver and Black Collets: 4 단계, 이미지 2개 중 2개
      • Silver-topped propeller collets unscrew counter-clockwise
      • Black-topped propeller collets unscrew clockwise
      댓글 쓰기
    2. DJI Phantom Case Top Shell Replacement, Unscrewing Silver Collets: 5 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Unscrewing Silver Collets: 5 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Unscrewing Silver Collets: 5 단계, 이미지 3개 중 3개
      • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
      • Once free, unscrew and remove the collet.
      댓글 쓰기
    3. DJI Phantom Case Top Shell Replacement, Unscrewing Black Collets: 6 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Unscrewing Black Collets: 6 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Unscrewing Black Collets: 6 단계, 이미지 3개 중 3개
      • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
      댓글 쓰기
    4. DJI Phantom Case Top Shell Replacement, Remove the Propeller: 7 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Remove the Propeller: 7 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Remove the Propeller: 7 단계, 이미지 3개 중 3개
      • Gently press down the motor shaft and lift the propeller up to remove it.
      댓글 쓰기
    1. DJI Phantom Case Top Shell Replacement, Remove Case Screws: 8 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Remove Case Screws: 8 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Remove Case Screws: 8 단계, 이미지 3개 중 3개
      • After removing all four propellors, flip the drone over.
      • Remove the following screws from the underside of the drone:
      • Twelve 2.0 mm hex screws
      • Four Phillips #0 screws
      댓글 쓰기
    2. DJI Phantom Case Top Shell Replacement, Unplug Magnetometer: 9 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Unplug Magnetometer: 9 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Unplug Magnetometer: 9 단계, 이미지 3개 중 3개
      • Loosen the cable from the plastic landing gear.
      • Unplug the magnetometer molex connector.
      댓글 쓰기
    3. DJI Phantom Case Top Shell Replacement, Remove the Top Shell: 10 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Remove the Top Shell: 10 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Remove the Top Shell: 10 단계, 이미지 3개 중 3개
      • Lift up on the top portion of the shell and set it on its side.
      • Do not attempt to fully remove the case. The GPS and Magnetometer cables connect the top shell to the rest of the Phantom, be careful not to stress or break these cables.
      댓글 쓰기
    4. DJI Phantom Case Top Shell Replacement, Disconnect GPS Cable: 11 단계, 이미지 2개 중 1개 DJI Phantom Case Top Shell Replacement, Disconnect GPS Cable: 11 단계, 이미지 2개 중 2개
      • Lift the GPS cable molex connector up out of its socket on the main board.
      댓글 쓰기
    5. DJI Phantom Case Top Shell Replacement, Loosen Magnetometer Cable: 12 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Loosen Magnetometer Cable: 12 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Loosen Magnetometer Cable: 12 단계, 이미지 3개 중 3개
      • Gently pull the slack of the magnetometer cable through the case bottom shell.
      • The case top shell should now have enough slack to work on the interior of the Phantom.
      댓글 쓰기
    1. DJI Phantom Case Top Shell Replacement, Twisting the Magnetometer Cable: 13 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Twisting the Magnetometer Cable: 13 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Twisting the Magnetometer Cable: 13 단계, 이미지 3개 중 3개
      • Twist the magnetometer cable as shown to prepare for passing it through the case bottom shell.
      댓글 쓰기
    2. DJI Phantom Case Top Shell Replacement, Passing Through the Magnetometer Cable: 14 단계, 이미지 3개 중 1개 DJI Phantom Case Top Shell Replacement, Passing Through the Magnetometer Cable: 14 단계, 이미지 3개 중 2개 DJI Phantom Case Top Shell Replacement, Passing Through the Magnetometer Cable: 14 단계, 이미지 3개 중 3개
      • Gently push the twisted magnetometer cable and molex connector through the hole in the case bottom shell.
      댓글 쓰기
    3. DJI Phantom Case Top Shell Replacement, Remove the Case Top Shell: 15 단계, 이미지 2개 중 1개 DJI Phantom Case Top Shell Replacement, Remove the Case Top Shell: 15 단계, 이미지 2개 중 2개
      • Remove the case top shell from the bottom shell.
      • If your new case top shell did not come with a GPS module, you may need to transfer the old one. To do so, gently peel off the large, gray adhesive label and transfer it to the new shell.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
David Hoyt
회원 가입일: 04/09/10
4,053 평판
안내서 39개를 작성함
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G89
4 회원들
안내서 263개를 작성함
1가이드 댓글
Thanks for all the steps which are very helpful. Could you please let us know what toos is needed to remove the GPS module from the top shell?
Hellephant Studio - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 54
전체 시간: 5,212
