주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DOPO 10.1 Tablet Dual .3 mega pixel Camera Replacement
필요한 것
    1. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 1 단계, 이미지 3개 중 1개 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 1 단계, 이미지 3개 중 2개 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Back of tablet: 1 단계, 이미지 3개 중 3개
      • You will have to remove the back of the tablet. To do this, take the plastic opening tool, and insert into the side of the tablet and twist. This will pop off the side.
      • Slowly pull up on the cover until it is completely off.
      댓글 쓰기
    2. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 2 단계, 이미지 3개 중 1개 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 2 단계, 이미지 3개 중 2개 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Relocating obstructions: 2 단계, 이미지 3개 중 3개
      • You may notice that the battery is in the way. No worries, it is easy to move. All you will need to do is to gently lift up on the battery with a small constant pressure to release it from the adhesive.
      • Carefully put it off to the side.
      • Once the battery is removed you will see a gray wire. Lightly lift up, and move it out of way.
      댓글 쓰기
    3. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 3 단계, 이미지 3개 중 1개 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 3 단계, 이미지 3개 중 2개 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from motherboard: 3 단계, 이미지 3개 중 3개
      • Locate where the camera is plugged into the motherboard. It should be on the left side of the motherboard just above the center.
      • Once located lift the black lever on the right side of the connector. This will release the camera.
      • Once the lever is lifted, pull out the camera by gently tugging the cameras connector tape.
      댓글 쓰기
    4. DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 4 단계, 이미지 3개 중 1개 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 4 단계, 이미지 3개 중 2개 DOPO 10.1 Tablet Dual  .3 mega pixel Camera  Replacement, Removing Camera from the device: 4 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove yellow tape that is securing the camera to the back cover.
      • Now take tweezers, and gently grab one of the cameras. Once grabbed, begin to twist to remove from device. Do this for both cameras.
      댓글 쓰기
결론
For information you can go to http://www.doublepowertech.com/download/...
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Kaitlyn Hayes
회원 가입일: 01/21/15
414 평판
안내서 4개를 작성함
USF Tampa, Team 5-2, Brown Winter 2015 USF Tampa, Team 5-2, Brown Winter 2015 회원
USFT-BROWN-W15S5G2
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 28
전체 시간: 662
