주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DOSS SoundBox Battery Replacement
필요한 것
    1. DOSS SoundBox Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 DOSS SoundBox Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
      • Use a magnetic mat to prevent the loss of screws.
      댓글 쓰기
    2. DOSS SoundBox Battery Replacement: 2 단계, 이미지 2개 중 1개 DOSS SoundBox Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
      • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
      댓글 쓰기
    3. DOSS SoundBox Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
      • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
      • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
      댓글 쓰기
    4. DOSS SoundBox Battery Replacement: 4 단계, 이미지 1개 중 1개
      • De-solder the connections from the battery to the circuit board.
      • If you do not already have a replacement battery, you can purchase one here.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brendan Harkreader
회원 가입일: 09/27/18
548 평판
안내서 3개를 작성함
5가이드 댓글
What could be the cause that the box works perfectly on low volume, but as soon as I raise the volume the box shuts down?
Thanks so much for your work here. :)
Milad Etemadi - 답글 공유
Hi. Thanks for the guide! Can you please let me know how to remove the existing batt, I don’t know if it’s glued or sthing but I can’t take it out, I m stuck there. Tks !!
Philly newrocker - 답글 공유
Did you manage to get it removed? I don’t know any more details than what this guide offered, but if it is glued in, isopropyl alcohol or some low heat are usually quite helpful. Make sure the battery is drained beforehand, of course, though I doubt it’ll be an issue since you’re trying to replace the battery, most likely because it’s not holding a charge anymore. If you use isopropyl, you can get fairly liberal with it without having to worry about damaging anything so long as you don’t get any on the speakers because the glue used to hold them together can desolve causing separation which would ruin the sound and would need repair.
Thousand Sunny - 답글 공유
Link for Battery Replacement is broken.
Michael Scibetta - 답글 공유
I believe this is the new link to replacement battery
Tenergy-37-2200-pcb
Fixer245 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 28
지난 30일: 120
전체 시간: 15,184
