주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DOSS SoundBox Motherboard Replacement
필요한 것
    1. DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: 1 단계, 이미지 3개 중 1개 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: 1 단계, 이미지 3개 중 2개 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: 1 단계, 이미지 3개 중 3개
      • Use a small plastic opening tool to gently lift the side of the grille.
      • Gently slide the tool to the front of the speaker.
      • Repeat the process on the bottom of the grille.
      • Gently pull the grille off of the speaker enclosure.
      • Pry with caution, for the grille is fragile.
      댓글 쓰기
    1. DOSS SoundBox Motherboard Replacement, Speaker: 2 단계, 이미지 2개 중 1개 DOSS SoundBox Motherboard Replacement, Speaker: 2 단계, 이미지 2개 중 2개
      • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
      • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
      • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
      • Using a Magnetic Mat throughout this process will help prevent losing screws.
      댓글 쓰기
    2. DOSS SoundBox Motherboard Replacement: 3 단계, 이미지 2개 중 1개 DOSS SoundBox Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
      댓글 쓰기
    3. DOSS SoundBox Motherboard Replacement: 4 단계, 이미지 2개 중 1개 DOSS SoundBox Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
      • The speakers are ready to be removed and replaced.
      • Ensure that the device is turned off when handling bare wire.
      • Soldering iron is very hot.
      댓글 쓰기
    1. DOSS SoundBox Motherboard Replacement, Battery: 5 단계, 이미지 2개 중 1개 DOSS SoundBox Motherboard Replacement, Battery: 5 단계, 이미지 2개 중 2개
      • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
      • Use a magnetic mat to prevent the loss of screws.
      댓글 쓰기
    2. DOSS SoundBox Motherboard Replacement: 6 단계, 이미지 2개 중 1개 DOSS SoundBox Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
      • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
      댓글 쓰기
    3. DOSS SoundBox Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
      • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
      • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
      댓글 쓰기
    4. DOSS SoundBox Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • De-solder the connections from the battery to the circuit board.
      • If you do not already have a replacement battery, you can purchase one here.
      댓글 쓰기
    1. DOSS SoundBox Motherboard Replacement, Motherboard: 9 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Follow the steps leading up to the actual battery removal, but do not actually remove the battery.
      • Remove the two 3/32" screws that attach the motherboard to the battery compartment using a JIS #00 screwdriver.
      • Use your fingers or a pair of tweezers to remove the clip holding the ribbon connector in place. The connector is indicated with an orange marker.
      • Be sure not to apply excessive force on the ribbon connector, as it can break.
      • Find the speaker connector, indicated by a yellow circle, and using your fingers disconnect it.
      댓글 쓰기
    2. DOSS SoundBox Motherboard Replacement: 10 단계, 이미지 2개 중 1개 DOSS SoundBox Motherboard Replacement: 10 단계, 이미지 2개 중 2개
      • Locate and remove the two 3/32" screws, indicated by red markers, that fix the motherboard to the speaker enclosure.
      댓글 쓰기
    3. DOSS SoundBox Motherboard Replacement: 11 단계, 이미지 3개 중 1개 DOSS SoundBox Motherboard Replacement: 11 단계, 이미지 3개 중 2개 DOSS SoundBox Motherboard Replacement: 11 단계, 이미지 3개 중 3개
      • Using the plastic opening tool, gently begin to pry the circuit card away from the speaker enclosure.
      • There is adhesive on the top of the motherboard, use caution while prying to avoid breakage.
      • Using your fingers, you can now remove the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Cassandra Remsing
회원 가입일: 10/02/18
136 평판
안내서 1개를 작성함
6가이드 댓글
Cassandra, the million dollar question is dWhere can i buy the motherboard for the SiundBox Doos.
please let me know at rubenalexander2611@hotmail.com, ahora todo lo mandan de la china please, a ver si me das una pagina web.
Ruben Diaz - 답글 공유
As Cassandra said before,,,,WHere we can find the parts??? is it any possibilities ?
bunker1312@gmail.com
bunker1312 - 답글 공유
Where to buy your motherboard for doss torch Bluetooth speaker
smoothjobbrian - 답글 공유
Ffs, Where do you get the board? Pretty useless writeup if there's no known location to aquire parts.
Christopher Cox - 답글 공유
I have taken the motherboard out. Where can I purchase another one as I don't see any link for that?
Paul Doran - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 96
전체 시간: 6,544
