주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DOSS SoundBox Speaker Replacement
필요한 것
    1. DOSS SoundBox Speaker Replacement, Speaker: 1 단계, 이미지 2개 중 1개 DOSS SoundBox Speaker Replacement, Speaker: 1 단계, 이미지 2개 중 2개
      • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
      • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
      • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
      • Using a Magnetic Mat throughout this process will help prevent losing screws.
      댓글 쓰기
    2. DOSS SoundBox Speaker Replacement: 2 단계, 이미지 2개 중 1개 DOSS SoundBox Speaker Replacement: 2 단계, 이미지 2개 중 2개
      • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
      댓글 쓰기
    3. DOSS SoundBox Speaker Replacement: 3 단계, 이미지 2개 중 1개 DOSS SoundBox Speaker Replacement: 3 단계, 이미지 2개 중 2개
      • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
      • The speakers are ready to be removed and replaced.
      • Ensure that the device is turned off when handling bare wire.
      • Soldering iron is very hot.
      댓글 쓰기
결론
To reassemble your device, follow instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Brendan Harkreader
회원 가입일: 09/27/18
548 평판
안내서 3개를 작성함
1가이드 댓글
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 48
전체 시간: 3,712
