주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DYMO LabelPOINT 100 Keypad Replacement
필요한 것
    1. DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: 2 단계, 이미지 2개 중 1개 DYMO LabelPOINT 100 Keypad Replacement, Remove Screws To The Access Panel: 2 단계, 이미지 2개 중 2개
      • Use Phillips #00 Screwdriver to remove the three screws that hold the upper portion of the access panel.
      • Remove the blade cutter assembly.
      • Use Phillips #00 Screwdriver to remove the last two screws located in the battery panel that holds the bottom portion of the access panel.
      댓글 쓰기
    2. DYMO LabelPOINT 100 Keypad Replacement, Remove Access Panel: 3 단계, 이미지 1개 중 1개
      • Gently remove the access panel from the right side of the device.
      • Some electrical wiring will be exposed and will not detach. Be careful not to damage any electrical wiring when removing access panel.
      댓글 쓰기
    3. DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: 4 단계, 이미지 2개 중 1개 DYMO LabelPOINT 100 Keypad Replacement, Removing Circuit Board: 4 단계, 이미지 2개 중 2개
      • Use Phillips #00 Screwdriver to remove three screws that hold down the circuit board.
      • Gently lift the bottom of the circuit board, revealing the keypad.
      • Be careful not to damage any components on the circuit board when disassembling.
      댓글 쓰기
    4. DYMO LabelPOINT 100 Keypad Replacement, Remove Keypad: 5 단계, 이미지 1개 중 1개
      • Remove the keypad from the front facing cover
      • When installing the new keypad, make sure all buttons are correctly set in each hole so that each button can be pressed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Mike Dam
회원 가입일: 09/25/14
201 평판
안내서 2개를 작성함
USF Tampa, Team 5-2, Mcgee Fall 2014 USF Tampa, Team 5-2, Mcgee Fall 2014 회원
USFT-MCGEE-F14S5G2
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 20
전체 시간: 1,535
