주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Daisy Model 10 Carbine Butt Replacement
필요한 것
    1. Daisy Model 10 Carbine Butt Replacement, Removing Screws: 1 단계, 이미지 3개 중 1개 Daisy Model 10 Carbine Butt Replacement, Removing Screws: 1 단계, 이미지 3개 중 2개 Daisy Model 10 Carbine Butt Replacement, Removing Screws: 1 단계, 이미지 3개 중 3개
      • Make sure the safety is on!
      • Place the carbine with the saddle ring and leather thong facing upwards.
      • Locate the screw head on the cocking lever.
      • There should be one on either side of the saddle ring and one on the cocking lever assembly.
      • Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
      • Completely remove the screws.
      • Be wary of the black washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
      댓글 쓰기
    2. Daisy Model 10 Carbine Butt Replacement, Removing the Lever: 2 단계, 이미지 2개 중 1개 Daisy Model 10 Carbine Butt Replacement, Removing the Lever: 2 단계, 이미지 2개 중 2개
      • Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
      • With your fingers in the handle, slide the lever towards the butt of the carbine.
      • Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
      댓글 쓰기
    1. Daisy Model 10 Carbine Butt Replacement, Removing Side Screws: 3 단계, 이미지 2개 중 1개 Daisy Model 10 Carbine Butt Replacement, Removing Side Screws: 3 단계, 이미지 2개 중 2개
      • Once the cocking lever is removed, place the carbine with the saddle ring facing upwards.
      • Locate the screws on either side of the saddle ring.
      • Using a #2 Phillips Screwdriver, twist in a counter-clockwise motion.
      • Completely remove the two screws.
      • Be wary of the two washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
      댓글 쓰기
    2. Daisy Model 10 Carbine Butt Replacement, Removing Top Screw: 4 단계, 이미지 2개 중 1개 Daisy Model 10 Carbine Butt Replacement, Removing Top Screw: 4 단계, 이미지 2개 중 2개
      • Now rotate your carbine so the top of the carbine is visible.
      • Locate the screw located above the saddle ring where the black metal meets the wooden butt.
      • Using the same #2 Phillips Screwdriver, twist in a counter-clockwise motion.
      • Completely remove the screw.
      • Be wary that this screw is a different length, and that there is no washer attached to it.
      댓글 쓰기
    3. Daisy Model 10 Carbine Butt Replacement, Removing the Butt: 5 단계, 이미지 2개 중 1개 Daisy Model 10 Carbine Butt Replacement, Removing the Butt: 5 단계, 이미지 2개 중 2개
      • Place your dominant hand on the wooden butt and your other hand on the metal barrel.
      • Slide the butt away from the Carbine until it is free of the metal tongs.
      • The butt will not slide out quickly. The metal tongs grip the butt so that it is a tight fit.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Trelawney Bullis
회원 가입일: 10/12/14
488 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 32
전체 시간: 876
