주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Daisy Model 10 Carbine Cocking Lever Replacement
필요한 것
    1. Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: 1 단계, 이미지 3개 중 1개 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: 1 단계, 이미지 3개 중 2개 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: 1 단계, 이미지 3개 중 3개
      • Make sure the safety is on!
      • Place the carbine with the saddle ring and leather thong facing upwards.
      • Locate the screw head on the cocking lever.
      • There should be one on either side of the saddle ring and one on the cocking lever assembly.
      • Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
      • Completely remove the screws.
      • Be wary of the black washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
      댓글 쓰기
    2. Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: 2 단계, 이미지 2개 중 1개 Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: 2 단계, 이미지 2개 중 2개
      • Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
      • With your fingers in the handle, slide the lever towards the butt of the carbine.
      • Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Timothy Gachot
회원 가입일: 10/12/14
237 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 38
전체 시간: 2,864
