주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Daylight Running Lamp Replacement
    1. Daylight Running Lamp Replacement, Locating and Removing the Bulb: 1 단계, 이미지 2개 중 1개 Daylight Running Lamp Replacement, Locating and Removing the Bulb: 1 단계, 이미지 2개 중 2개
      • Open the hood of the car and locate the running light, (red circle) at the end of the headlamp housing. Look for the bulb holder, a piece of plastic or metal that holds the bulb in place inside the headlight housing.
      • Using your fingers, slightly rotate (orange arrows) the plastic piece bulb holder, unlocking it. Remove it along with the bulb.
      댓글 쓰기
      • Press the bulb down slightly and twist it to remove it from the holder. Replace the bulb by doing the same: press the new bulb down and twist it (in the opposite direction) to secure it in the holder.
      • Finally, insert the holder with the new bulb back into the headlight, turning back to it's 'locked' position. Remember the position of the holder when removing it, so that it can be reinserted in the correct position
      • Ready! You have changed the running lamp yourself and acquired knowledge.
      댓글 쓰기
결론
It is recommended you verify the replacement bulb is appropriate for your vehicle. It's possible they vary by model. Please consult a workshop, specialized center, or a trusted website.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
Juan Garcia님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
El Mécanico Español
회원 가입일: 06/26/24
472 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 67
전체 시간: 471
