주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DeLonghi ESAM 3000.B Magnifica disassembling
필요한 것
    1. DeLonghi ESAM 3000.B Magnifica disassembling, Preparations: 1 단계, 이미지 1개 중 1개
      • Pull the plug!
      • Remove the drip tray, the water tank and the pulp container.
      댓글 쓰기
    2. DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew the rear panel: 2 단계, 이미지 2개 중 1개 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew the rear panel: 2 단계, 이미지 2개 중 2개
      • The rear panel and side panels are attached with six phillips screws #2. Screw them out.
      댓글 쓰기
    3. DeLonghi ESAM 3000.B Magnifica disassembling, Remove right side panel: 3 단계, 이미지 2개 중 1개 DeLonghi ESAM 3000.B Magnifica disassembling, Remove right side panel: 3 단계, 이미지 2개 중 2개
      • Slide the right side panel about 2 cm to the back.
      • Then solve it.
      댓글 쓰기
    4. DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: 4 단계, 이미지 3개 중 1개 DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: 4 단계, 이미지 3개 중 2개 DeLonghi ESAM 3000.B Magnifica disassembling, Remove left side panel: 4 단계, 이미지 3개 중 3개
      • The left side is a bit stuck. Place a plastic opening tool in the gap between the front and left side panel above the opening for the water tank. Lift the gap slightly larger.
      • Then place the tool in the gap between the front and left side panel under the opening for the water tank. Increase the gap and push the side part about 2 cm to the rear.
      • Lift out the left side piece.
      댓글 쓰기
    5. DeLonghi ESAM 3000.B Magnifica disassembling, Remove rear panel: 5 단계, 이미지 1개 중 1개
      • Take out the rear panel.
      댓글 쓰기
    6. DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: 6 단계, 이미지 3개 중 1개 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: 6 단계, 이미지 3개 중 2개 DeLonghi ESAM 3000.B Magnifica disassembling, Unscrew top cover: 6 단계, 이미지 3개 중 3개
      • The front panel is secured with four PH2 Phillips screws, two left and one right each. Turn it out.
      • Use a plastic opening tool to lever off the steam tap.
      • Carefully pull the front panel about 1 cm forward so that there is a gap between the top cover and the front panel,
      • Do not pull the front panel too far, it is still attached with different hoses and cables.
      댓글 쓰기
    7. DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: 7 단계, 이미지 3개 중 1개 DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: 7 단계, 이미지 3개 중 2개 DeLonghi ESAM 3000.B Magnifica disassembling, Remove top cover: 7 단계, 이미지 3개 중 3개
      • Two Phillips screws PH2 hold the lid at the back. Turn it out.
      • Lift the lid upwards.
      댓글 쓰기
결론
Follow the steps in reverse order to reassemble your device.
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
VauWeh
회원 가입일: 10/19/15
338,688 평판
안내서 311개를 작성함
4가이드 댓글
Bonjour et merci pour le partage;
Comment démonter le panneau de commandes à l’avant svp, il semblerait que le bouton rond qui permet de régler la quantité d’eau par tasse ne répond plus normalement. En effet en choisissant une double tasse et en ayant tourner ce bouton au maximum pour la quantité de café par tasse, j’obtiens un tiers de bol…ce bouton se serait il décalé??? ou est ce plutôt un autre problème? avez vous une idée svp? Merci d’avance pour vos réponses.
Laurence MUNSCH - 답글 공유
Le régulateur réagit-il ? Si vous le retournez, est-ce qu'il produit aussi moins de café ? Il existe de nombreuses possibilités : le débitmètre, la pompe, le piston supérieur…
VauWeh - 답글 공유
Bonjour j ai le bouton service toujours allumé. Pas détartrage mais je pense un problème électrique.
Qq peux m aider merci
yacoub bouanene - 답글 공유
Utilisez le mode test pour trouver une solution. C'est en allemand, traduisez avec Google Translate.
VauWeh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 85
지난 30일: 448
전체 시간: 29,962
