주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DeWalt DW997 Forward/Reverse Switch Replacement
필요한 것
    1. DeWalt DW997 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: 1 단계, 이미지 1개 중 1개
      • There should be 7 screws that are 21 mm long, remove them with a TorxT15 bit.
      • There should be 1 screw that is 18 mm long, remove it with a Torx T10 bit.
      • Note: Keep all 8 screws together to avoid losing them .
      댓글 쓰기
    2. DeWalt DW997 Forward/Reverse Switch  Replacement: 2 단계, 이미지 2개 중 1개 DeWalt DW997 Forward/Reverse Switch  Replacement: 2 단계, 이미지 2개 중 2개
      • Once all screws are removed, remove the plastic siding by slowly prying open the two sides all the way around.
      • Caution: Do not pry the two pieces apart with a tool. Once all the screws are out, the two parts should split.
      댓글 쓰기
    3. DeWalt DW997 Forward/Reverse Switch  Replacement: 3 단계, 이미지 3개 중 1개 DeWalt DW997 Forward/Reverse Switch  Replacement: 3 단계, 이미지 3개 중 2개 DeWalt DW997 Forward/Reverse Switch  Replacement: 3 단계, 이미지 3개 중 3개
      • Locate the forward/reverse switch above the trigger. Lift up the copper colored trigger assembly and lift up the switch with two fingers.
      • Note: The switch should easily come out.
      댓글 쓰기
    4. DeWalt DW997 Forward/Reverse Switch  Replacement: 4 단계, 이미지 2개 중 1개 DeWalt DW997 Forward/Reverse Switch  Replacement: 4 단계, 이미지 2개 중 2개
      • Take the replacement switch and place it in the trigger assembly that the faulty switch was removed from. The new switch has two legs on one side, the bigger triangular shaped leg should be towards the front of the drill.
      • Note: The side of the switch that has the two legs is placed facing down.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Juan Endara
회원 가입일: 09/12/16
216 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 61
전체 시간: 4,743
