주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DeWalt DWE4011 Power Cable Replacement
필요한 것
    1. DeWalt DWE4011 Power Cable Replacement, Power Cord: 1 단계, 이미지 1개 중 1개
      • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
      댓글 쓰기
    2. DeWalt DWE4011 Power Cable Replacement: 2 단계, 이미지 2개 중 1개 DeWalt DWE4011 Power Cable Replacement: 2 단계, 이미지 2개 중 2개
      • Remove bottom casing by separating the end handle away from the main casing.
      댓글 쓰기
    3. DeWalt DWE4011 Power Cable Replacement: 3 단계, 이미지 2개 중 1개 DeWalt DWE4011 Power Cable Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the 1/2” (13mm) Phillips #2 screw holding the power cable to the device. This will free up the metal clamp holding the cable in place.
      댓글 쓰기
    4. DeWalt DWE4011 Power Cable Replacement: 4 단계, 이미지 1개 중 1개
      • Flip the grinder over and disconnect the plastic switch mechanism from the cable housing.
      댓글 쓰기
    5. DeWalt DWE4011 Power Cable Replacement: 5 단계, 이미지 2개 중 1개 DeWalt DWE4011 Power Cable Replacement: 5 단계, 이미지 2개 중 2개
      • Pull back the yellow tab holding the housing in place using a nylon spudger. Carefully pull the housing out of the casing.
      댓글 쓰기
    6. DeWalt DWE4011 Power Cable Replacement: 6 단계, 이미지 2개 중 1개 DeWalt DWE4011 Power Cable Replacement: 6 단계, 이미지 2개 중 2개
      • Locate the terminals with the two white cables attached and disconnect both.
      • These cables are connected to the outer terminals; connect as such during reassembly.
      댓글 쓰기
    7. DeWalt DWE4011 Power Cable Replacement: 7 단계, 이미지 2개 중 1개 DeWalt DWE4011 Power Cable Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the entirety of the cable housing from the device casing.
      • The two wires coming from the power cable should still be connected to electrical housing at this point.
      댓글 쓰기
    8. DeWalt DWE4011 Power Cable Replacement: 8 단계, 이미지 1개 중 1개
      • Loosen the Phillips #2 screws enough to disconnect the two wires from the power cable housing.
      • Removing the screw entirely is fine, but unnecessary since the screws are merely clamping down the wires' ends.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
kean colosimo
회원 가입일: 04/02/19
241 평판
안내서 1개를 작성함
1가이드 댓글
Where can I find a replacement power cord?
Ethan Sligar - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 67
전체 시간: 4,810
