주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Debadging a Ferrari
필요한 것
동영상 개요
    1. Debadging a Ferrari, Find and remove any bolts: 1 단계, 이미지 2개 중 1개 Debadging a Ferrari, Find and remove any bolts: 1 단계, 이미지 2개 중 2개
      • Depending on the model of Ferrari you own, you may need to remove several bolts that hold the badge in place.
      • The badge that is being removed in this tutorial is from the Ferrari 458's front passenger side, and the bolts can be found underneath the inner wheel well.
      댓글 쓰기
    2. Debadging a Ferrari, Line the badge with masking tape: 2 단계, 이미지 1개 중 1개
      • Line the badge of your Ferrari with masking tape as shown.
      • This is done to protect the surrounding paint during the removal process.
      댓글 쓰기
    3. Debadging a Ferrari, Soften your adhesive with the heat gun: 3 단계, 이미지 1개 중 1개
      • Warm up the badge using your heat gun.
      • Take care not to over heat the badge! You're only softening the adhesive underneath the badge, not cooking it.
      • Think of how warm the exterior of a car gets when it sits out in the sun during the summer. That will act as your reference point.
      댓글 쓰기
    4. Debadging a Ferrari, Cutting your adhesive: 4 단계, 이미지 2개 중 1개 Debadging a Ferrari, Cutting your adhesive: 4 단계, 이미지 2개 중 2개
      • Using the plastic prying tool, carefully pry up one corner of the badge, and slip the floss underneath.
      • You don't want to use too much force on the prying tool, as this can result in denting.
      • Draw the floss back and forth in a sawing motion and simultaneously pull it along the perimeter of the badge until it detaches from the panel.
      • Do not use metal fishing line or metal wires, as these will damage your paint.
      댓글 쓰기
    5. Debadging a Ferrari, Clean off the leftover adhesive: 5 단계, 이미지 1개 중 1개
      • With the badge removed you can now use soapy water and the abrasive side of a sponge to remove the excess adhesive. Other products such as Goo Gone or Goof Off are also excellent adhesive removers.
      • Take care not to scrub not too hard, as this can ruin your paint.
      댓글 쓰기
결론
To reattach your badge, apply new adhesive and follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Jacob Mehnert
회원 가입일: 10/18/21
49,554 평판
안내서 52개를 작성함
iFanatics iFanatics 회원
Community
69 회원들
안내서 480개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 47
전체 시간: 1,527
