주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell AC511 USB Cable Replacement
필요한 것
    1. Dell AC511 USB Cable Replacement, Front Panel: 1 단계, 이미지 3개 중 1개 Dell AC511 USB Cable Replacement, Front Panel: 1 단계, 이미지 3개 중 2개 Dell AC511 USB Cable Replacement, Front Panel: 1 단계, 이미지 3개 중 3개
      • Use a Jimmy to peel off the screen stuck to the front of the speaker.
      • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
      • Be careful to avoid damage to the rest of the speaker and especially to yourself.
      • Don't worry if it tears; use the Jimmy again to peel off the rest.
      댓글 쓰기
    2. Dell AC511 USB Cable Replacement: 2 단계, 이미지 2개 중 1개 Dell AC511 USB Cable Replacement: 2 단계, 이미지 2개 중 2개
      • Remove ten 6 mm screws using a Phillips #1 screwdriver.
      댓글 쓰기
    3. Dell AC511 USB Cable Replacement: 3 단계, 이미지 2개 중 1개 Dell AC511 USB Cable Replacement: 3 단계, 이미지 2개 중 2개
      • Lift the front panel off of the rest of the device.
      • The speakers will still be attached to the front panel. Being too rough could damage them.
      • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
      • Remove the front panel from the device.
      댓글 쓰기
    1. Dell AC511 USB Cable Replacement, Speaker: 4 단계, 이미지 2개 중 1개 Dell AC511 USB Cable Replacement, Speaker: 4 단계, 이미지 2개 중 2개
      • Follow the three wires connected to the speaker to find where they connect to the circuit board.
      • Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
      댓글 쓰기
    1. Dell AC511 USB Cable Replacement, USB Cable: 5 단계, 이미지 2개 중 1개 Dell AC511 USB Cable Replacement, USB Cable: 5 단계, 이미지 2개 중 2개
      • Depending on where the soundbar is damaged, there are two different ways to remove the USB cable. This guide will cover both scenarios.
      • Remove the 6 mm screws connecting the circuit board to the rear panel using a Phillips #1 screwdriver.
      댓글 쓰기
    2. Dell AC511 USB Cable Replacement: 6 단계, 이미지 2개 중 1개 Dell AC511 USB Cable Replacement: 6 단계, 이미지 2개 중 2개
      • If the small wires coming from the USB cable are disconnected from the board, you'll have to solder them on. We recommend not letting that happen if you can help it.
      • The small wires may be glued to the circuit board. Pry off the glue with the Halberd Spudger.
      댓글 쓰기
    3. Dell AC511 USB Cable Replacement: 7 단계, 이미지 1개 중 1개
      • Follow this step if the wires are still connected. If they aren't, skip to the next step.
      • If the wiring to the circuit board seems fine, use a razor or wire strippers to clear the rubber insulation away from the USB.
      • Keep track of the colors! If you connect the wrong wires together, the speaker won't work, and you could ruin the board!
      • After removing the rubber insulation from the smaller wires, remove the access USB.
      • Splice in the new USB and wrap the connection with the colored wires in electrical tape.
      • If you end up with reduced sound quality, you may need to solder after all. Continue to the next step in that case.
      댓글 쓰기
    4. Dell AC511 USB Cable Replacement: 8 단계, 이미지 1개 중 1개
      • Follow this step if the wires are not connected.
      • Remove the old USB wiring as best as possible from the circuit board.
      • Try to not be too rough. If needed, use wire strippers to remove the wires.
      • Remember the locations of the color coded USB wires and solder each into their respective places.
      • Take your time. Do not add too much solder; you could potentially fry the board if you do.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
William Cook
회원 가입일: 03/19/24
653 평판
안내서 6개를 작성함
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G6
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 36
전체 시간: 534
