주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell AC511 Volume Knob Replacement
필요한 것
    1. Dell AC511 Volume Knob Replacement, Front Panel: 1 단계, 이미지 3개 중 1개 Dell AC511 Volume Knob Replacement, Front Panel: 1 단계, 이미지 3개 중 2개 Dell AC511 Volume Knob Replacement, Front Panel: 1 단계, 이미지 3개 중 3개
      • Use a Jimmy to peel off the screen stuck to the front of the speaker.
      • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
      • Be careful to avoid damage to the rest of the speaker and especially to yourself.
      • Don't worry if it tears; use the Jimmy again to peel off the rest.
      댓글 쓰기
    2. Dell AC511 Volume Knob Replacement: 2 단계, 이미지 2개 중 1개 Dell AC511 Volume Knob Replacement: 2 단계, 이미지 2개 중 2개
      • Remove ten 6 mm screws using a Phillips #1 screwdriver.
      댓글 쓰기
    3. Dell AC511 Volume Knob Replacement: 3 단계, 이미지 2개 중 1개 Dell AC511 Volume Knob Replacement: 3 단계, 이미지 2개 중 2개
      • Lift the front panel off of the rest of the device.
      • The speakers will still be attached to the front panel. Being too rough could damage them.
      • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
      • Remove the front panel from the device.
      댓글 쓰기
    1. Dell AC511 Volume Knob Replacement, Volume Knob: 4 단계, 이미지 1개 중 1개
      • Apply a light downward pressure on the circuit board next to the volume control.
      • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
      댓글 쓰기
    2. Dell AC511 Volume Knob Replacement: 5 단계, 이미지 1개 중 1개
      • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
      • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
William Cook
회원 가입일: 03/19/24
653 평판
안내서 6개를 작성함
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G6
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 29
전체 시간: 391
