주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Alienware 15 R3 Battery Replacement
필요한 것
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Dell Alienware 15 R3 Battery Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Dell Alienware 15 R3 Battery Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
    댓글 쓰기
  2. Dell Alienware 15 R3 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
    댓글 쓰기
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
    댓글 쓰기
  4. Dell Alienware 15 R3 Battery Replacement: 4 단계, 이미지 2개 중 1개 Dell Alienware 15 R3 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
    댓글 쓰기
  5. Dell Alienware 15 R3 Battery Replacement: 5 단계, 이미지 3개 중 1개 Dell Alienware 15 R3 Battery Replacement: 5 단계, 이미지 3개 중 2개 Dell Alienware 15 R3 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
    댓글 쓰기
  6. Dell Alienware 15 R3 Battery Replacement, Battery: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
    댓글 쓰기
  7. Dell Alienware 15 R3 Battery Replacement: 7 단계, 이미지 3개 중 1개 Dell Alienware 15 R3 Battery Replacement: 7 단계, 이미지 3개 중 2개 Dell Alienware 15 R3 Battery Replacement: 7 단계, 이미지 3개 중 3개
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jake Nelson
회원 가입일: 09/22/22
642 평판
안내서 7개를 작성함
2가이드 댓글
does not seem to be for my alienware r3 15 inch
Craig Anderson - 답글 공유
step 5 - you need to unscrew 10 screws, not 9. You missed the one in the center.
Mike Kravchenko - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 35
지난 30일: 180
전체 시간: 10,382
