주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Alienware M11x R3 RAM Replacement
필요한 것
  1. Dell Alienware M11x R3 RAM Replacement, Lower Case: 1 단계, 이미지 3개 중 1개 Dell Alienware M11x R3 RAM Replacement, Lower Case: 1 단계, 이미지 3개 중 2개 Dell Alienware M11x R3 RAM Replacement, Lower Case: 1 단계, 이미지 3개 중 3개
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
    댓글 쓰기
  2. Dell Alienware M11x R3 RAM Replacement, RAM: 2 단계, 이미지 3개 중 1개 Dell Alienware M11x R3 RAM Replacement, RAM: 2 단계, 이미지 3개 중 2개 Dell Alienware M11x R3 RAM Replacement, RAM: 2 단계, 이미지 3개 중 3개
    • On the top stick of RAM, push each of the two tabs away from the side as shown in the second picture.
    • Once the tabs are pushed out of the way, the stick of RAM will automatically pop up as shown in the third picture. At this point, you can simply slide the stick of RAM out of the slot.
    • Repeat this process for the bottom stick.
    댓글 쓰기
  3. Dell Alienware M11x R3 RAM Replacement: 3 단계, 이미지 3개 중 1개 Dell Alienware M11x R3 RAM Replacement: 3 단계, 이미지 3개 중 2개 Dell Alienware M11x R3 RAM Replacement: 3 단계, 이미지 3개 중 3개
    • With both sticks out you are ready to put the new ones in. Each stick has a small notch on the left side splitting the gold contacts. This is for the alignment pin.
    • Starting with the bottom stick of RAM, align the pin and insert the stick at the same angle you removed the old one. Once it is gently pushed in all the way, push the stick down as shown in the third picture until it locks under the retaining springs.
    • Repeat this process for the second stick of RAM.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Richard Maurice
회원 가입일: 03/08/17
534 평판
안내서 6개를 작성함
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 UMass Dartmouth, Team S3-G7, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G7
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 28
전체 시간: 1,136
