주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Dimension 4600 Fan Replacement
  1. Dell Dimension 4600 Fan Replacement, Side Panel: 1 단계, 이미지 1개 중 1개
    • Locate the case cover latch on the back of the computer.
    댓글 쓰기
  2. Dell Dimension 4600 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
    댓글 쓰기
  3. Dell Dimension 4600 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Grab the edge of the panel and slide it away from the case until it is removed.
    댓글 쓰기
  4. Dell Dimension 4600 Fan Replacement, Fan: 4 단계, 이미지 1개 중 1개
    • Lay the computer flat on it's side so that you are looking down at all of the components.
    • Locate the fan and its black, red, and white power cable.
    댓글 쓰기
  5. Dell Dimension 4600 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
    댓글 쓰기
  6. Dell Dimension 4600 Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the release clip on the side of the fan and hold it down with your thumb.
    댓글 쓰기
  7. Dell Dimension 4600 Fan Replacement: 7 단계, 이미지 1개 중 1개
    • While holding the release clip down, look on the outside of the case where the fan lies.
    • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tim
회원 가입일: 10/12/11
76 평판
안내서 1개를 작성함
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 회원
CPSU-REGAN-F11S6G10
4 회원들
안내서 11개를 작성함
1가이드 댓글
Thank you, the pictures are very good. My Dell 4600 had a green baffle that funneled the air through the heat sink fins. There is a little latch at the bottom which allows the this to swing open. Because the back of my PC is full of 13 years worth of cables, I did this without lying the PC down and without disconnecting the fan connector from the mother board. I am amazed at how quiet the PC is now.
pxcozzol - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 32
전체 시간: 6,563
