주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Dimension 4600 Video Card Replacement
필요한 것
  1. Dell Dimension 4600 Video Card Replacement, Side Panel: 1 단계, 이미지 1개 중 1개
    • Locate the case cover latch on the back of the computer.
    댓글 쓰기
  2. Dell Dimension 4600 Video Card Replacement: 2 단계, 이미지 1개 중 1개
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
    댓글 쓰기
  3. Dell Dimension 4600 Video Card Replacement: 3 단계, 이미지 1개 중 1개
    • Grab the edge of the panel and slide it away from the case until it is removed.
    댓글 쓰기
  4. Dell Dimension 4600 Video Card Replacement, Video Card: 4 단계, 이미지 1개 중 1개
    • Lay the computer flat so that you are looking down on all of the components.
    댓글 쓰기
  5. Dell Dimension 4600 Video Card Replacement: 5 단계, 이미지 1개 중 1개
    • Locate the Video Card and the screw attached to the Video Card as shown in the picture.
    댓글 쓰기
  6. Dell Dimension 4600 Video Card Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
    댓글 쓰기
  7. Dell Dimension 4600 Video Card Replacement: 7 단계, 이미지 1개 중 1개
    • Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
    댓글 쓰기
  8. Dell Dimension 4600 Video Card Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the remainder of the card up and out of it's slot.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Arvind
회원 가입일: 10/12/11
395 평판
안내서 2개를 작성함
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 회원
CPSU-REGAN-F11S6G10
4 회원들
안내서 11개를 작성함
2가이드 댓글
I have a question - My dell dimension 4600 has lines going down the screen, ive tried 3 different monitors, reinstalling windows (reinstalling would have lines going down the screen, after installing all programs the system freezes up with lines going down the screen nothing else) ive tried system restore can someone tell me whats going on?
Don't hurt the chickens - 답글 공유
That sounds like either a GPU failure or internal Graphics failure. Have you checked thermal paste?
William Morgan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 42
전체 시간: 8,160
