주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell E193FPc Interface Buttons Replacement
필요한 것
    1. Dell E193FPc Interface Buttons Replacement, Stand: 1 단계, 이미지 1개 중 1개
      • Lay the monitor screen-down so the back screws are exposed.
      • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
      댓글 쓰기
    2. Dell E193FPc Interface Buttons Replacement: 2 단계, 이미지 1개 중 1개
      • Gently lift and pull away the stand at a slight angle away from the monitor.
      댓글 쓰기
    1. Dell E193FPc Interface Buttons Replacement, Display Bezel: 3 단계, 이미지 2개 중 1개 Dell E193FPc Interface Buttons Replacement, Display Bezel: 3 단계, 이미지 2개 중 2개
      • Locate the two holes on the bottom of the monitor.
      • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
      • This task is much easier if two people pry simultaneously at each hole.
      • Continue prying along the entire edge of the monitor.
      댓글 쓰기
    2. Dell E193FPc Interface Buttons Replacement: 4 단계, 이미지 2개 중 1개 Dell E193FPc Interface Buttons Replacement: 4 단계, 이미지 2개 중 2개
      • When finished prying, the plastic will partially fall away from the rest of the monitor.
      • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
      • While holding the frames together, carefully flip the monitor over so it faces screen down.
      • Gently lift and remove remove the rear case from the monitor.
      댓글 쓰기
    3. Dell E193FPc Interface Buttons Replacement: 5 단계, 이미지 3개 중 1개 Dell E193FPc Interface Buttons Replacement: 5 단계, 이미지 3개 중 2개 Dell E193FPc Interface Buttons Replacement: 5 단계, 이미지 3개 중 3개
      • Locate the green interface button board.
      • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
      • Lift the monitor interior away from the front cover.
      댓글 쓰기
    1. Dell E193FPc Interface Buttons Replacement, Interface Buttons: 6 단계, 이미지 1개 중 1개
      • Behind the front panel of the plastic cover lies the button strip.
      • Remove the buttons by gently pulling up on the strip.
      • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Charley Grove
회원 가입일: 10/10/11
101 평판
안내서 1개를 작성함
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G36
4 회원들
안내서 24개를 작성함
1가이드 댓글
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 33
전체 시간: 2,684
