주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell E193FPc Inverter Board Replacement
필요한 것
    1. Dell E193FPc Inverter Board Replacement, Stand: 1 단계, 이미지 1개 중 1개
      • Lay the monitor screen-down so the back screws are exposed.
      • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
      댓글 쓰기
    2. Dell E193FPc Inverter Board Replacement: 2 단계, 이미지 1개 중 1개
      • Gently lift and pull away the stand at a slight angle away from the monitor.
      댓글 쓰기
    1. Dell E193FPc Inverter Board Replacement, Display Bezel: 3 단계, 이미지 2개 중 1개 Dell E193FPc Inverter Board Replacement, Display Bezel: 3 단계, 이미지 2개 중 2개
      • Locate the two holes on the bottom of the monitor.
      • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
      • This task is much easier if two people pry simultaneously at each hole.
      • Continue prying along the entire edge of the monitor.
      댓글 쓰기
    2. Dell E193FPc Inverter Board Replacement: 4 단계, 이미지 2개 중 1개 Dell E193FPc Inverter Board Replacement: 4 단계, 이미지 2개 중 2개
      • When finished prying, the plastic will partially fall away from the rest of the monitor.
      • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
      • While holding the frames together, carefully flip the monitor over so it faces screen down.
      • Gently lift and remove remove the rear case from the monitor.
      댓글 쓰기
    3. Dell E193FPc Inverter Board Replacement: 5 단계, 이미지 3개 중 1개 Dell E193FPc Inverter Board Replacement: 5 단계, 이미지 3개 중 2개 Dell E193FPc Inverter Board Replacement: 5 단계, 이미지 3개 중 3개
      • Locate the green interface button board.
      • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
      • Lift the monitor interior away from the front cover.
      댓글 쓰기
    1. Dell E193FPc Inverter Board Replacement, Inverter Board: 6 단계, 이미지 3개 중 1개 Dell E193FPc Inverter Board Replacement, Inverter Board: 6 단계, 이미지 3개 중 2개 Dell E193FPc Inverter Board Replacement, Inverter Board: 6 단계, 이미지 3개 중 3개
      • With the monitor facing down, remove the two 5.81 mm Phillips #2 screws on the right side of the metal casing.
      • With the monitor still facing down, remove the two 5.81 mm Phillips #2 screws on the left side of the casing.
      • Do attempt to pull apart the casing. There are still wires holding the front and back together.
      댓글 쓰기
    2. Dell E193FPc Inverter Board Replacement: 7 단계, 이미지 1개 중 1개
      • Using a 5 mm nut driver, unscrew the VGA port's mounting screws from the metal casing.
      댓글 쓰기
    3. Dell E193FPc Inverter Board Replacement: 8 단계, 이미지 1개 중 1개
      • With the monitor facing down, gently lift the back case away from the rest of the monitor to expose the inverter board and mother board.
      • Recall that the casing is still held together by several wires. Do not attempt to fully remove the back casing.
      댓글 쓰기
    4. Dell E193FPc Inverter Board Replacement: 9 단계, 이미지 2개 중 1개 Dell E193FPc Inverter Board Replacement: 9 단계, 이미지 2개 중 2개
      • The inverter board is the smaller board in the corner.
      • Remove the three 7.69 mm Phillips #2 screws from the inverter board.
      • Remove the two 7.69 mm Phillips #2 grounding screws from the wire with the black connector.
      • Gently pull the inverter board away from the case. Note that the board is still connected to several components by wires.
      댓글 쓰기
    5. Dell E193FPc Inverter Board Replacement: 10 단계, 이미지 2개 중 1개 Dell E193FPc Inverter Board Replacement: 10 단계, 이미지 2개 중 2개
      • There is a wire connecting the motherboard to the inverter board. Squeeze both sides of the connector and pull to remove it from the socket.
      • There is another wire connecting the button board to the inverter board. Remove the second white wire connector.
      • A third wire connects the inverter board to the screen circuit board. Remove the black wire connector.
      • The inverter board can now be fully removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Mackenzie Keane
회원 가입일: 10/04/11
523 평판
안내서 5개를 작성함
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G36
4 회원들
안내서 48개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 36
전체 시간: 5,437
